From the May 2016 issue
Exploring Hercules
While the stars are comparatively faint, they hold some notable targets for binocular stargazers.
By | Published: May 30, 2016 | Last updated on May 18, 2023
Harrington
Welcome to my binocular universe. It’s good to be back. Each month, you and I are going to venture outside, binoculars in hand, to explore the sky. While many view binoculars as stepping-stones on the way to a telescope, I see them as fine instruments in their own right. The low power and wide fields of view make binoculars ideal for both a casual scan as well as for many sophisticated observing programs.
Most of the targets that I’ll feature will be visible through common size binoculars. But just to mix it up a little, we will also feature at least one “challenge object” that may only be visible through 10×70 and larger models.
This first column kicks off with a survey of the sky’s legendary strongman, Hercules. While the stars in Hercules are comparatively faint, they hold some notable targets for binocular stargazers.
Hercules Cluster
The Hercules Cluster, M13, is one of the finest globular clusters visible from the Northern Hemisphere.
R. Jay GaBany
First and foremost is the Hercules Cluster, M13. No other globular cluster north of the celestial equator puts on such a grand display. To find it, first find the constellation’s Keystone asterism, a trapezoid of four moderately bright stars about two-thirds of the way from Arcturus (Alpha [α] Boötis) to Vega (Alpha Lyrae). M13 lies between Eta [η] and Zeta [ζ] Herculis along the western side of the Keystone.
You may even spot it without optical aid under a dark sky. Through binoculars, M13 looks like a tuft of celestial cotton. Standing to either side are two faint “sentry stars,” as if guarding a vault of diamonds.
It’s hard to believe, but that little puff is actually a collection of some 300,000 stars. Unfortunately, they lie 25,000 light-years away and are so tightly packed that we can’t hope to resolve them through binoculars. We are in good company, because neither could Charles Messier (1730–1817) when he added it to his burgeoning catalog of counterfeit comets.
M92
Globular cluster M92 lies 26,000 light-years away and is visible as a fuzzy haze through binoculars.
Neil Fleming
Most observers are so captivated by M13 that they forget the second globular cluster in Hercules that is also a Messier object. M92 may not stand out like its more flamboyant neighbor, but it is still easily visible through properly aimed binoculars. You’ll find it about a binocular field north of Pi [π] Herculis, the northeastern star in the Keystone.
M92 shines at magnitude 6.5, roughly half a magnitude fainter than M13, and appears only half as large. But since M92 lies about the same distance from us, at 26,000 light-years, it’s fun to see just how different two globulars can appear.
Our final stop in this great constellation is at the planetary nebula NGC 6210, this month’s binocular challenge. Planetary nebulae are expanding gas clouds expelled by aging, pulsating stars. They almost always appear small when seen from Earth, which makes identifying even the brightest through binoculars a real challenge.
NGC 6210
Planetary nebula NGC 6210 appears as a bluish-green “star” when viewed with good binoculars.
Chris Schur
NGC 6210 rates 9th magnitude, just within the brightness barrier of 50mm binoculars. Of course, with its disk only measuring 15″ across, it will look like a star — a distinctly blue-green star. That color should help set it apart. NGC 6210 has been nicknamed the Turtle Nebula for the four leg-like protrusions extending from its shell-shaped disk seen in photographs.
NGC 6210 lies 8° south of Zeta Herculis. That’s a little more than a typical binocular field of view. There are two 7th-magnitude stars nearby, one to its south and another to its southeast. Remember to look for a bluish-green star; that will be NGC 6210.
Join me next month as we delve deep into the center of our galaxy. Until then, remember my mantra: Two eyes are better than one.
