Hubble: Keep both options open
After much debate about the space-based telescope's future, NASA has taken a step toward, or away from, a solution.
By | Published: January 7, 2005 | Last updated on May 18, 2023
Dextre
If NASA decides to send a robotic mission to save Hubble, a modified Dextre is the probable candidate.
MDA
January 7, 2005
Even though astronomers argue the Hubble Space Telescope requires a manned servicing mission (or something similar) to make necessary repairs, yesterday, NASA approved MacDonald, Dettwiler and Associates Ltd. (MDA) of Brampton, Ontario, to pursue a design concept for a possible robotic mission. The technology will be based on Dextre the dual-armed robot built by MDA under contract to the Canadian Space Agency to conduct exterior maintenance of the International Space Station.
Although NASA has not committed to a robotic mission, the MDA contract, valued at $154 million, is a small step toward it.
Dextre is specially designed to perform complex tasks — such as installing and removing batteries, power supplies, computer units, and scientific payloads — in the harsh environment of space. The robot will be adapted to replace Hubble’s batteries and failing gyroscopes.
In addition, it will install the Cosmic Origins Spectrograph (COS) — an instrument that is especially sensitive to far-ultraviolet light and is capable of seeing exceedingly faint UV objects — and the Wide-Field Camera 3 (WFC3). COS will continue where the Space Telescope Imaging Spectrograph left off, studying intergalactic gas in the very early universe as well as the formation of the first galaxies. WFC3 will image a wide range of light — from infrared through visible to ultraviolet — to add to our understanding of dark energy and star formation, among other cosmological questions.
If NASA allows Servicing Mission 4 to continue, Hubble’s batteries and gyroscopes will be replaced and enhanced instruments (the COS and the WFC3) added in order to continue the telescope’s exciting discoveries. A de-orbit module will be added to guide Hubble safely through the atmosphere at the end of its life.
NASA
A December report issued by the National Academies’ National Research Council concluded there are too many limitations on a robotic mission — time, budget, success rate — for such a mission to be feasible. “The design of such a mission, as well as the immaturity of the technology involved and the inability to respond to unforeseen failures, make it highly unlikely that NASA will be able to extend the scientific lifetime of the telescope through robotic servicing,” said panel chair Louis Lanzerotti, a solar-terrestrial research professor at the New Jersey Institute of Technology. The committee strongly recommended sending a manned mission to fix Hubble.
If NASA decides to continue with a robotic mission, launch is not expected until December of 2007. Hubble’s batteries or remaining gyroscopes could fail by then, and there is no way to fix the telescope after that point is reached.
