Friction causes Enceladus’ plumes
Tidal forces acting on fault lines in the moon's icy shell cause the faults to rub back and forth against each other, producing enough heat to transform some of the ice into plumes of water vapor and ice crystals.Provided by the University of California, Santa Cruz
By | Published: May 16, 2007 | Last updated on May 18, 2023
False-color plumes
This false-color view shows the extent of Enceladus’ fountain-like plumes, which emanate from the moon’s warm south polar region.
NASA / JPL / SSI
May 16, 2007
Rubbing your hands together on a cold day generates a bit of heat, and the same process of frictional heating may be what powers the geysers jetting out from the surface of Saturn’s moon Enceladus.
Tidal forces acting on fault lines in the moon’s icy shell cause the sides of the faults to rub back and forth against each other, producing enough heat to transform some of the ice into plumes of water vapor and ice crystals, according to a new study published in the May 17 issue of the journal Nature.
Francis Nimmo, assistant professor of Earth and planetary sciences at the University of California, Santa Cruz, and his coauthors calculated the amount of heat that could be generated by this mechanism and concluded that it is the most likely explanation for the plumes and other features observed in the south polar region of Enceladus. This region is warmer than the rest of the frozen surface of Enceladus and has features called “tiger stripes” that look like tectonic fault lines.
“We think the tiger stripes are the source of the plumes, and we made predictions of where the tiger stripes should be hottest that can be tested by future measurements,” Nimmo says.
Driving the whole process is the moon’s eccentric orbit, which brings it close to Saturn and then farther away, so that the gravitational attraction it feels changes over time.
“It’s getting squeezed and stretched as it goes around Saturn, and those tidal forces cause the faults to move back and forth,” Nimmo says.
Unlike some other proposals for the origin of the plumes, this mechanism does not require the presence of liquid water near the surface of Enceladus, noted coauthor Robert Pappalardo of NASA’s Jet Propulsion Laboratory in Pasadena.
“The heat is sufficient to cause ice to sublimate, like in a comet — the ice evaporates into vapor, and the escaping vapor drags particles off into space,” Pappalardo says.
The study does suggest, however, that Enceladus has a liquid ocean lying deep beneath the ice. That allows the ice shell to deform enough to produce the necessary movement in the faults. If the ice shell sat directly on top of the moon’s rocky interior, tidal forces would not produce enough movement in the faults to generate heat, Nimmo explains.
The frictional or “shear heating” mechanism is consistent with an earlier study by Nimmo and Pappalardo, in which they proposed that Enceladus reoriented itself to position the hot spot at the south pole. In that study, the researchers described how the reorientation of Enceladus would result from a lower density of the thick ice shell in this region.
In the new paper, the researchers estimated the thickness of the ice shell to be at least 3 miles (5 kilometers) and probably several tens of miles or kilometers. They also estimated that the movement along the fault lines is about half a meter over the course of a tidal period.
In addition to Nimmo and Pappalardo, the coauthors of the paper include John Spencer of the Southwest Research Institute in Boulder, Colorado, and McCall Mullen of the University of Colorado, Boulder. This study was funded by NASA’s Planetary Geology and Geophysics and Outer Planets research programs.
Enceladus has sparked great interest among scientists, particularly since the discovery more than a year ago by NASA’s Cassini spacecraft of the geysers shooting off its surface. This is one of two papers about Enceladus appearing in the May 17 issue of Nature. In the other paper, scientists explain how cracks in the icy surface of Enceladus open and close under Saturn’s pull. Saturn’s tides could control the timing of the geysers’ eruptions, researchers suggest.
