Hubble helps Dawn
Astronomers use Hubble images of Vesta and Ceres to prepare for spacecraft Dawn's mission to the asteroid belt.Provided by Space Telescope Science Institute
By | Published: June 27, 2007 | Last updated on May 18, 2023
The Hubble Space Telescop imaged Ceres, shown above, and Vesta, two massive asteroids in the asteroid belt between Mars and Jupiter, using Hubble’s Wide Field Planetary Camera 2. Astronomers are using these images to prepare for the Dawn spacecraft’s journey to the two asteroids. After launching July 7 on a four-year journey, Dawn will orbit Ceres in 2015.
NASA, ESA, J. Parker (Southwest Research Institute), and L. McFadden (Univ. of Maryland)
June 27, 2007
Hubble Space Telescope images of Vesta and Ceres are helping astronomers plan for the Dawn spacecraft’s tour of these hefty asteroids. The images show two of the most massive asteroids in the asteroid belt, a region between Mars and Jupiter.
On July 7, NASA is scheduled to launch the spacecraft on a four-year journey to the asteroid belt. Once there, Dawn will do some asteroid-hopping, orbiting Vesta in 2011 and Ceres in 2015. Dawn will be the first spacecraft to orbit two targets. At least 100,000 asteroids inhabit the asteroid belt, a reservoir of leftover material from the formation of our solar system’s planets 4.6 billion years ago.
Dawn also will be the first satellite to tour a dwarf planet. The International Astronomical Union named Ceres one of three dwarf planets in 2006. Ceres is round like planets in our solar system, but it does not clear debris out of its orbit as our planets do.
To prepare for the Dawn spacecraft’s visit to Vesta, astronomers used Hubble’s Wide Field Planetary Camera 2 to snap new images of the asteroid. Using Hubble, astronomers mapped Vesta’s southern hemisphere, a region dominated by a giant impact crater formed by a collision billions of years ago. The crater is 285 miles (456 kilometers) across, which is nearly equal to Vesta’s 330-mile (530-kilometer) diameter. If Earth had a crater of proportional size, it would fill the Pacific Ocean basin. The impact broke off chunks of rock, producing more than 50 smaller asteroids that astronomers have nicknamed “vestoids.” The collision also may have blasted through Vesta’s crust. Vesta is about the size of Arizona.
The Dawn spacecraft will orbit Vesta, imaged May 14, in 2011. Astronomers used Hubble to map Vesta’s southern hemisphere, which has a 285-mile wide crater. Vesta’s diameter is only 330 miles.
Previous Hubble images of Vesta’s southern hemisphere were taken in 1994 and 1996 with the wide-field camera. In this new set of images, Hubble’s sharp “eye” can see features as small as about 37 miles (60 kilometers) across. The image shows the difference in brightness and color on the asteroid’s surface. These characteristics hint at the large-scale features that the Dawn spacecraft will see when it arrives at Vesta.
Hubble’s view reveals extensive global features stretching longitudinally from the northern hemisphere to the southern hemisphere. The image also shows widespread differences in brightness in the east and west, which probably reflect compositional changes. Both of these characteristics could reveal volcanic activity throughout Vesta. The size of these different regions varies. Some are hundreds of miles across.
The brightness differences could be similar to the effect seen on the Moon, where smooth, dark regions are more iron-rich than the brighter highlands that contain minerals richer in calcium and aluminum. When Vesta was forming 4.5 billion years ago, it was heated to the melting temperatures of rock. This heating allowed heavier material to sink to Vesta’s center and lighter minerals to rise to the surface.
Astronomers combined images of Vesta in two colors to study the variations in iron-bearing minerals. From these minerals, they hope to learn more about Vesta’s surface structure and composition. Astronomers expect that Dawn will provide rich details about the asteroid’s surface and interior structure.
The Hubble image of Ceres reveals bright and dark regions on the asteroid’s surface that could be topographic features, such as craters, and/or areas containing different surface material. Large impacts may have caused some of these features and potentially added new material to the landscape. The Texas-sized asteroid holds about 30 to 40 percent of the mass in the asteroid belt.
Ceres’ round shape suggests that its interior is layered like those of terrestrial planets, such as Earth. The asteroid may have a rocky inner core, an icy mantle, and a thin, dusty outer crust. The asteroid may even have water locked beneath its surface. It is approximately 590 miles (950 kilometers) across and was the first asteroid discovered, in 1801.
The observations were made in visible and ultraviolet light between December 2003 and January 2004 with the Advanced Camera for Surveys. The color variations in the image show either a difference in texture or composition on Ceres’ surface. Astronomers need the close-up views of the Dawn spacecraft to determine the characteristics of these regional differences.
