Enceladus more active than thought
Cassini finds water vapor and natural chemicals at Saturn's geyser moon.Provided by NASA Headquarters, Washington, D.C.
By | Published: March 27, 2008 | Last updated on May 18, 2023
heat on Enceladus
Heat radiating from the entire length of 95 mile-long fractures is seen in this best-yet heat map of the active south polar region of Saturn’s ice moon Enceladus.
March 27, 2008
NASA’s Cassini spacecraft tasted and sampled a surprising organic brew erupting in geyser-like fashion from Saturn’s moon Enceladus during a close flyby on March 12. Scientists are amazed that this tiny moon is so active, hot and brimming with water vapor and organic chemicals.
New heat maps of the surface show higher temperatures than previously known in the south pole region, with hot tracks running the length of giant fissures. Additionally, scientists say the organics “taste and smell” like some of those found in a comet. The jets themselves harmlessly peppered Cassini, exerting measurable torque on the spacecraft, and providing an indirect measure of the plume density.
“A completely unexpected surprise is that the chemistry of Enceladus, what’s coming out from inside, resembles that of a comet,” says Hunter Waite, principal investigator for the Cassini Ion and Neutral Mass Spectrometer at the Southwest Research Institute in San Antonio. “To have primordial material coming out from inside a Saturn moon raises many questions on the formation of the Saturn system.”
“Enceladus is by no means a comet. Comets have tails and orbit the Sun, and Enceladus’ activity is powered by internal heat while comet activity is powered by sunlight. Enceladus’ brew is like carbonated water with an essence of natural gas,” says Waite.
The Ion and Neutral Mass Spectrometer saw a much higher density of volatile gases, water vapor, carbon dioxide and carbon monoxide, as well as organic materials, some 20 times denser than expected. This dramatic increase in density was evident as the spacecraft flew over the area of the plumes.
Enceladus
New structure, density and composition measurements of Enceladus’ water plume were obtained when the Cassini spacecraft’s Ultraviolet Imaging Spectrograph observed the star zeta Orionis pass behind the plume Oct. 24, 2007, as seen in this image.
NASA/JPL
New high-resolution heat maps of the south pole by Cassini’s Composite Infrared Spectrometer show that the so-called tiger stripes, giant fissures that are the source of the geysers, are warm along almost their entire lengths, and reveal other warm fissures nearby. These more precise new measurements reveal temperatures of at least -135° F. That is 63° warmer than previously seen and 200° warmer than other regions of the moon. The warmest regions along the tiger stripes correspond to two of the jet locations seen in Cassini images.
“These spectacular new data will really help us understand what powers the geysers. The surprisingly high temperatures make it more likely that there’s liquid water not far below the surface,” says John Spencer, Cassini scientist on the Composite Infrared Spectrometer team at the Southwest Research Institute in Boulder, Colorado.
Previous ultraviolet observations showed four jet sources, matching the locations of the plumes seen in previous images. This indicates that gas in the plume blasts off the surface into space, blending to form the larger plume.
Images from previous observations show individual jets and mark places from which they emanate. New images show how hot spot fractures are related to other surface features. In future imaging observations, scientists hope to see individual plume sources and investigate differences among fractures.
“Enceladus has got warmth, water and organic chemicals, some of the essential building blocks needed for life,” says Dennis Matson, Cassini project scientist at NASA’s Jet Propulsion Laboratory. “We have quite a recipe for life on our hands, but we have yet to find the final ingredient, liquid water, but Enceladus is only whetting our appetites for more.”
At closest approach, Cassini was only 30 miles from Enceladus. When it flew through the plumes it was 120 miles from the moon’s surface. Cassini’s next flyby of Enceladus is in August.
