Astronomers dissect a giant stellar explosion
This analysis provides information for what may prove to be one of the most important gamma-ray bursts (GRBs) seen in recent years.Provided by ESA, Noordwijk, Netherlands
By | Published: April 3, 2009 | Last updated on May 18, 2023
Center of a collapsing star
This artist’s impression shows the center of a dying star collapsing minutes before the star implodes. The blast from a Gamma Ray Burst is thought to be produced by a jet of fast-moving gas that bursts from near the central engine, probably a black hole created by such a collapse of the massive star.
NASA/Dana Berry
April 3, 2009
The Integral satellite has captured one of the brightest gamma-ray bursts ever seen. A meticulous analysis of the data has allowed astronomers to investigate the initial phases of this giant stellar explosion, which led to the ejection of matter at velocities close to the speed of light. In particular, the astronomers believe that the explosion lifted a piece of the central engine’s magnetic field into space.
On December 19, 2004, the blast from an exploding star arrived at Earth. The European Space Agency’s (ESA) Integral satellite, an orbiting gamma-ray observatory, recorded the entire event, providing information for what may prove to be one of the most important gamma-ray bursts (GRBs) seen in recent years. As the data were collected, astronomers saw the 500-second-long burst rise to extraordinary brilliance.
“It is in the top 1 percent of the brightest GRBs we have seen,” said Diego Götz, CEA Saclay, France, who headed the investigation.
The brightness of the event, known as GRB 041219A, has allowed the team to investigate a property known as the polarization of the gamma rays. The team has shown that the gamma rays were highly polarized and varied tremendously in level and orientation.
Polarization refers to the preferred direction in which the radiation wave oscillates. Polaroid sunglasses work with visible light by letting through only a single direction of polarization, blocking most of the light from entering our eyes.
The blast from a GRB is thought to be produced by a jet of fast-moving gas bursting from near the central engine, probably a black hole created by the collapse of the massive star. The polarization is directly related to the structure of the magnetic field in the jet. So it is one of the best ways for astronomers to investigate how the central engine produces the jet. There is a number of ways this might happen.
In the first scenario, the jet carries a portion of the central engine’s magnetic field into space. A second involves the jet generating the magnetic field far from the central engine. A third concerns the extreme case in which the jet contains no gas, just magnetic energy, and a fourth scenario entails the jet moving through an existing field of radiation.
In each of the first three scenarios, the polarization is generated by what is called synchrotron radiation. The magnetic field traps particles, known as electrons, and forces them to spiral, releasing polarized radiation. In the fourth scenario, the polarization is imparted through interactions between the electrons in the jet and photons in the existing radiation field.
Götz believes that the Integral results favor a synchrotron model and, of those three, the most likely scenario is the first, in which the jet lifts the central engine’s magnetic field into space. “It is the only simple way to do it,” he said.
Götz would like to measure the polarization for every GRB, to see whether the same mechanism applies to all. Unfortunately, many GRBs are too faint for the current instrumentation to succeed. Even the state-of-the-art IBIS instrument on Integral can only record the polarization state of gamma rays if a celestial source is as bright as GRB 041219A.
“So, for now we just have to wait for the next big one,” he said.
