“The Sun contains huge rivers of plasma similar to Earth’s ocean currents,” said Andres Munoz-Jaramillo from the Harvard-Smithsonian Center for Astrophysics (CfA). “Those plasma rivers affect solar activity in ways we’re just beginning to understand.”
The Sun is made of a fourth state of matter — plasma, in which negative electrons and positive ions flow freely. Flowing plasma creates magnetic fields, which lie at the core of solar activity like flares, eruptions, and sunspots.
Astronomers have known for decades that the Sun’s activity rises and falls in a cycle that lasts 11 years on average. At its most active, called solar maximum, dark sunspots dot the Sun’s surface, and frequent eruptions send billions of tons of hot plasma into space. If the plasma hits Earth, it can disrupt communications and electrical grids and short out satellites.
During solar minimum, the Sun calms down, and both sunspots and eruptions are rare. The effects on Earth, while less dramatic, are still significant. For example, Earth’s outer atmosphere shrinks closer to the surface, meaning there is less drag on orbiting space junk. Also, the solar wind that blows through the solar system, and its associated magnetic field, weakens, allowing more cosmic rays to reach us from interstellar space.
The most recent solar minimum had an unusually long number of spotless days: 780 days during 2008-2010. In a typical solar minimum, the Sun goes spot-free for about 300 days, making the last minimum the longest since 1913.
“The last solar minimum had two key characteristics: a long period of no sunspots and a weak polar magnetic field,” said Munoz-Jaramillo. (A polar magnetic field is the magnetic field at the Sun’s north and south poles.) “We have to explain both factors if we want to understand the solar minimum.”
To study the problem, Munoz-Jaramillo used computer simulations to model the Sun’s behavior over 210 activity cycles spanning some 2,000 years. He specifically looked at the role of the plasma rivers that circulate from the Sun’s equator to higher latitudes. These currents flow much like Earth’s ocean currents — rising at the equator, streaming toward the poles, then sinking and flowing back to the equator. At a typical speed of 40 mph (64 km/h), it takes about 11 years to make one loop.
Munoz-Jaramillo and his colleagues discovered that the Sun’s plasma rivers speed up and slow down like a malfunctioning conveyor belt. They find that a faster flow during the first half of the solar cycle, followed by a slower flow in the second half of the cycle, can lead to an extended solar minimum. The cause of the speedup and slowdown likely involves a complicated feedback between the plasma flow and solar magnetic fields.
“It’s like a production line — a slowdown puts distance between the end of the last solar cycle and the start of the new one,” said Munoz-Jaramillo.
The ultimate goal of studies like this is to predict upcoming solar maxima and minima — both their strength and timing. The team focused on simulating solar minima, and say that they can’t forecast the next solar minimum, which is expected to occur in 2019, just yet.
“We can’t predict how the flow of these plasma rivers will change,” said Dibyendu Nandi from the Indian Institute of Science Education and Research in Kolkata. “Instead, once we see how the flow is changing, we can predict the consequences.”
