A disturbed galactic duo
A gravitational tug-of-war has warped the spiral shape of NGC 3169 and fragmented the dust lanes in its companion, NGC 3166.
By | Published: April 21, 2011 | Last updated on May 18, 2023
The galaxies in this cosmic pairing, captured by the Wide Field Imager on the MPG/ESO 2.2-meter telescope at the La Silla Observatory in Chile, display some curious features, demonstrating that each member of the duo is close enough to feel the distorting gravitational influence of the other. The gravitational tug-of-war has warped the spiral shape of one galaxy, NGC 3169, and fragmented the dust lanes in its companion, NGC 3166. Meanwhile, a third, smaller galaxy to the lower right, NGC 3165, has a front-row seat to the gravitational twisting and pulling of its bigger neighbors.
This galactic grouping, found about 70 million light-years away in the constellation Sextans, was discovered by the English astronomer William Herschel in 1783. Modern astronomers have gauged the distance between NGC 3169 (left) and NGC 3166 (right) as a mere 50,000 light-years, a separation that is only about half the diameter of the Milky Way Galaxy. In such tight quarters, gravity can start to play havoc with galactic structure.
Spiral galaxies like NGC 3169 and NGC 3166 tend to have orderly swirls of stars and dust pinwheeling about their glowing centers. Close encounters with other massive objects can jumble this classic configuration, often serving as a disfiguring prelude to the merging of galaxies into one larger object. So far, the interactions of NGC 3169 and NGC 3166 have just lent a bit of character. NGC 3169’s arms, shining bright with big, young, blue stars, have been teased apart, and lots of luminous gas has been drawn out from its disk. In NGC 3166’s case, the dust lanes that also usually outline spiral arms are in disarray. Unlike its bluer counterpart, NGC 3166 is not forming many new stars.
NGC 3169 has another distinction: the faint yellow dot beaming through a veil of dark dust just to the left of and close to the galaxy’s center. This flash is the leftover of a supernova detected in 2003 and known accordingly as SN 2003cg. A supernova of this variety, classified as a type Ia, is thought to occur when a dense, hot star called a white dwarf — a remnant of medium-sized stars like our Sun — gravitationally sucks gas away from a nearby companion star. This added fuel eventually causes the whole star to explode in a runaway fusion reaction.
The new image presented here of a remarkable galactic dynamic duo is based on data selected by Igor Chekalin for the European Southern Observatory’s Hidden Treasures 2010 astrophotography competition. Chekalin won the first overall prize and this image received the second-highest ranking of the nearly 100 contest entries.
This image from the Wide Field Imager on the MPG/ESO 2.2-meter telescope at the La Silla Observatory in Chile captures the pair of galaxies NGC 3169 (left) and NGC 3166 (right). These adjacent galaxies display some curious features, demonstrating that each member of the duo is close enough to feel the distorting gravitational influence of the other. The gravitational tug-of-war has warped the spiral shape of one galaxy, NGC 3169, and fragmented the dust lanes in its companion NGC 3166.
ESO/Igor Chekalin
