NASA’s WISE mission discovers coolest class of stars
These six Y dwarfs, found within 40 light-years of the Sun, have the heat of a human body.
By and | Published: August 24, 2011 | Last updated on May 18, 2023
Scientists using data from NASA’s Wide-field Infrared Survey Explorer (WISE) have discovered the coldest class of star-like objects, with temperatures as cool as the human body.
Astronomers hunted these dark orbs, termed Y dwarfs, for more than a decade without success. When viewed with a visible-light telescope, they are nearly impossible to see. WISE’s infrared vision allowed the telescope to finally spot the faint glow of six Y dwarfs relatively close to our Sun, within a distance of about 40 light-years.
“WISE scanned the entire sky for these and other objects and was able to spot their feeble light with its highly sensitive infrared vision,” said Jon Morse from NASA Headquarters in Washington. “They are 5,000 times brighter at the longer infrared wavelengths WISE observed from space than those observable from the ground.”
The Y’s are the coldest members of the brown dwarf family. Brown dwarfs are sometimes referred to as “failed” stars. They are too low in mass to fuse atoms at their cores and thus don’t burn with the fires that keep stars like our Sun shining steadily for billions of years. Instead, these objects cool and fade with time, until what little light they do emit is at infrared wavelengths.
Astronomers study brown dwarfs to better understand how stars form and understand the atmospheres of planets beyond our solar system. The atmospheres of brown dwarfs are similar to those of gas giant planets like Jupiter, but they are easier to observe because they are alone in space, away from the blinding light of a parent star.
So far, WISE data has revealed 100 new brown dwarfs. More discoveries are expected as scientists continue to examine the enormous quantity of data from WISE. The telescope performed the most advanced survey of the sky at infrared wavelengths to date, from January 2010 to February 2011, scanning the entire sky about 1.5 times.
Of the 100 brown dwarfs, six are classified as cool Y’s. One of the Y dwarfs, called WISE 1828+2650, is the record holder for the coldest brown dwarf with an estimated atmospheric temperature cooler than room temperature, or less than 80° Fahrenheit (25° Celsius).
“The brown dwarfs we were turning up before this discovery were more like the temperature of your oven,” said Davy Kirkpatrick from the California Institute of Technology (CALTECH) in Pasadena, California. “With the discovery of Y dwarfs, we’ve moved out of the kitchen and into the cooler parts of the house.”
The Y dwarfs are in our Sun’s neighborhood, from approximately 9 to 40 light-years away. The Y dwarf approximately 9 light-years away, WISE 1541-2250, may become the seventh-closest star system, bumping Ross 154 back to eighth. By comparison, the star closest to our solar system, Proxima Centauri, is about 4 light-years away.
“Finding brown dwarfs near our Sun is like discovering there’s a hidden house on your block that you didn’t know about,” Cushing said. “It’s thrilling to me to know we’ve got neighbors out there yet to be discovered. With WISE, we may even find a brown dwarf closer to us than our closest known star.”
Once the WISE team identified brown dwarf candidates, they turned to NASA’s Spitzer Space Telescope to narrow their list. To definitively confirm them, the WISE team used some of the most powerful telescopes on Earth to split apart the objects’ light and look for telltale molecular signatures of water, methane, and possibly ammonia. For the coldest of the new Y dwarfs, the team used NASA’s Hubble Space Telescope. The Y dwarfs were identified based on a change in these spectral features compared to other brown dwarfs, indicating they have a lower atmospheric temperature.
Y-dwarf
This artist’s conception illustrates what a “Y dwarf” might look like. Y dwarfs are the coldest star-like bodies known, with temperatures that can be even cooler than the human body. Image credit: NASA/JPL-Caltech
