NASA survey counts potentially hazardous asteroids
Findings indicate there are roughly 4,700 near-Earth asteroids with orbits close to Earth’s and diameters larger than 330 feet (100 meters)
By and | Published: May 21, 2012 | Last updated on May 18, 2023
Potentially-hazardous-asteroids
New results from NASA’s NEOWISE survey find that more potentially hazardous asteroids (PHAs) are closely aligned with the plane of our solar system than previous models suggested. PHAs are the subset of near-Earth asteroids (NEAs) with the closest orbits to Earth’s orbit, coming within 5 million miles (8 million kilometers). They are also defined as being large enough to survive passage through Earth’s atmosphere and cause damage on a regional, or greater, scale. Credit: NASA/JPL-Caltech
Observations from NASA’s Wide-field Infrared Survey Explorer (WISE) have led to the best assessment yet of our solar system’s population of potentially hazardous asteroids. The results reveal new information about their total numbers, origins, and the possible dangers they may pose.
Potentially hazardous asteroids (PHAs) are a subset of the larger group of near-Earth asteroids. The PHAs have the closest orbits to Earth’s, coming within 5 million miles (8 million kilometers), and they are big enough to survive passing through Earth’s atmosphere and cause damage on a regional, or greater, scale.
The new results come from the asteroid-hunting portion of the WISE mission, called NEOWISE. The project sampled 107 PHAs to make predictions about the entire population as a whole. Findings indicate there are roughly 4,700 PHAs, plus or minus 1,500, with diameters larger than 330 feet (100 meters). So far, an estimated 20 to 30 percent of these objects have been found.
While previous estimates of PHAs predicted similar numbers, they were rough approximations. NEOWISE has generated a more credible estimate of the objects’ total numbers and sizes.
“The NEOWISE analysis shows us we’ve made a good start at finding those objects that truly represent an impact hazard to Earth,” said Lindley Johnson from NASA Headquarters in Washington, D.C. “But we’ve many more to find, and it will take a concerted effort during the next couple of decades to find all of them that could do serious damage or be a mission destination in the future.”
The new analysis also suggests that about twice as many PHAs as previously thought are likely to reside in “lower-inclination” orbits, which are more aligned with the plane of Earth’s orbit. In addition, these lower-inclination objects appear to be somewhat brighter and smaller than the other near-Earth asteroids that spend more time far away from Earth. A possible explanation is that many of the PHAs may have originated from a collision between two asteroids in the main belt lying between Mars and Jupiter. A larger body with a low-inclination orbit may have broken up in the main belt, causing some of the fragments to drift into orbits closer to Earth and eventually become PHAs.
Asteroids with lower-inclination orbits would be more likely to encounter Earth and would be easier to reach. The results, therefore, suggest more near-Earth objects might be available for future robotic or human missions.
“NASA’s NEOWISE project, which wasn’t originally planned as part of WISE, has turned out to be a huge bonus,” said Amy Mainzer from NASA’s Jet Propulsion Laboratory in Pasadena, California. “Everything we can learn about these objects helps us understand their origins and fate. Our team was surprised to find the overabundance of low-inclination PHAs. Because they will tend to make more close approaches to Earth, these targets can provide the best opportunities for the next generation of human and robotic exploration.”
The discovery that many PHAs tend to be bright says something about their composition; they are more likely to be either stony, like granite, or metallic. This type of information is important in assessing the space rocks’ potential hazards to Earth. The composition of the bodies would affect how quickly they might burn up in our atmosphere if an encounter were to take place.
The WISE spacecraft scanned the sky twice in infrared light before entering hibernation mode in early 2011. It cataloged hundreds of millions of objects, including super-luminous galaxies, stellar nurseries, and closer-to-home asteroids. The NEOWISE project snapped images of about 600 near-Earth asteroids, about 135 of which were new discoveries. Because the telescope detected the infrared light, or heat, of asteroids, it was able to pick up both light and dark objects, resulting in a more representative look at the entire population. The infrared data allowed astronomers to make good measurements of the asteroids’ diameters and, when combined with visible light observations, how much sunlight they reflect.
