Spitzer finds evidence for an exoplanet smaller than Earth
Data from the space telescope revealed an unexpected world orbiting closer to its star than Mercury is to the Sun.
Exoplanet-UCF-1.01
This artist's concept shows what astronomers believe is an alien world just two-thirds the size of Earth — one of the smallest on record. It was identified by NASA's Spitzer Space Telescope. The exoplanet candidate, known as UCF-1.01, orbits a star called GJ 436, which is located a mere 33 light-years away. UCF-1.01 might be the nearest world to our solar system that is smaller than our home planet. Image credit: NASA/JPL-Caltech
Astronomers using NASA's Spitzer Space Telescope have detected what they believe is a planet two-thirds the size of Earth. The exoplanet candidate, called UCF-1.01, is located a mere 33 light-years away, making it possibly the nearest world to our solar system that is smaller than our home planet.
Exoplanets circle stars beyond our Sun. Only a handful smaller than Earth have been found so far. Spitzer has performed transit studies on known exoplanets, but UCF-1.01 is the first ever identified with the telescope, pointing to a possible role for Spitzer in helping discover potentially habitable, terrestrial-sized worlds.
"We have found strong evidence for a very small, very hot, and very near planet with the help of the Spitzer Space Telescope," said Kevin Stevenson from the University of Central Florida in Orlando. "Identifying nearby small planets such as UCF-1.01 may one day lead to their characterization using future instruments."
The hot new planet candidate was found unexpectedly in Spitzer observations. Stevenson and his colleagues were studying the Neptune-sized exoplanet GJ 436b, already known to exist around the red dwarf star GJ 436. In the Spitzer data, the astronomers noticed slight dips in the amount of infrared light streaming from the star, separate from the dips caused by GJ 436b. A review of Spitzer archival data showed the dips were periodic, suggesting a second planet might be blocking out a small fraction of the star's light.
This technique, used by a number of observatories, including NASA's Kepler space telescope, relies on transits to detect exoplanets. The duration of a transit and the small decrease in the amount of light registered reveals basic properties of an exoplanet, such as its size and distance from its star. In UCF-1.01's case, its diameter would be approximately 5,200 miles (8,400 kilometers), or two-thirds that of Earth. UCF-1.01 would revolve quite tightly around GJ 436, at about seven times the distance of Earth from the Moon, with its "year" lasting only 1.4 Earth days. Given this proximity to its star, far closer than the planet Mercury is to our Sun, the exoplanet's surface temperature would be more than 1000° Fahrenheit (600° Celsius).
If the roasted, diminutive planet candidate ever had an atmosphere, it almost surely has evaporated. UCF-1.01 might therefore resemble a cratered, mostly geologically dead world like Mercury. Joseph Harrington, also from the University of Central Florida, suggested another possibility — that the extreme heat of orbiting so close to GJ 436 has melted the exoplanet's surface. "The planet could even be covered in magma," he said.
In addition to UCF-1.01, Stevenson and his colleagues noticed hints of a third planet, dubbed UCF-1.02, orbiting GJ 436. Spitzer has observed evidence of the two new planets several times each. However, even the most sensitive instruments are unable to measure exoplanet masses as small as UCF-1.01 and UCF-1.02, which are perhaps only one-third the mass of Earth. Because knowing the mass is required for confirming a discovery, scientists are cautiously calling both bodies exoplanet candidates for now.
Of the approximately 1,800 stars identified by Kepler as candidates for having planetary systems, just three are verified to contain sub-Earth-sized exoplanets. Of these, only one exoplanet is thought to be smaller than the Spitzer candidates, with a radius similar to Mars or 57 percent that of Earth.
"I hope future observations will confirm these exciting results, which show Spitzer may be able to discover exoplanets as small as Mars," said Michael Werner from NASA's Jet Propulsion Laboratory (JPL) in Pasadena, California. "Even after almost nine years in space, Spitzer's observations continue to take us in new and important scientific directions."
ExploringMarsBooklet_2
