Herschel intercepts asteroid Apophis
Data shows the asteroid is bigger than first estimated and less reflective.
RELATED TOPICS: SOLAR SYSTEM | ASTEROIDS | APHOPHIS | HERSCHEL
Asteroid-Apophis
Herschel’s three-color view of asteroid Apophis. // Credit: ESA
The European Space Agency’s (ESA) Herschel Space Observatory made new observations of asteroid Apophis as it approached Earth. The data shows the asteroid is bigger than first estimated and less reflective.
Cataloged as asteroid (99942) Apophis (previously 2004 MN4), it is often nicknamed “the doomsday asteroid” in popular media after initial observations made after its discovery in 2004 gave it a 2.7 percent chance of striking Earth in April 2029.
With additional data, however, an impact in 2029 was soon ruled out, although the asteroid will pass within 22,000 miles (36,000 kilometers) of Earth's surface, closer even than the orbits of geostationary satellites.
The asteroid will return to Earth's neighborhood again in 2036, but quite how close it will come then is uncertain, as the 2029 approach is predicted to alter its orbit substantially. Obtaining improved physical parameters for Apophis and its orbit is thus of great importance in being able to make better predictions of its future trajectory.
Herschel had a good opportunity during the weekend, observing the asteroid for about two hours on its approach to Earth, ahead of the January 9 closest encounter at a little less than one-tenth of the distance from Earth to the Sun — about 9.0 million miles (14.5 million km). The observations were made as part of Herschel's Guaranteed Time Program MACH-11.
"As well as the data being scientifically important in their own right, understanding key properties of asteroids will provide vital details for missions that might eventually visit potentially hazardous objects," said Laurence O'Rourke from the European Space Astronomy Center (ESAC) near Madrid, Spain. "Apophis is only the second near-Earth asteroid observed by Herschel, and these were the fastest tracked observations by the space telescope — the asteroid moved at a rate of 205 arcseconds per hour as seen from Herschel's viewpoint."
Herschel provided the first thermal infrared observations of Apophis at different wavelengths, which, together with optical measurements, helped refine estimates of the asteroid's properties. Previous estimates bracketed the asteroid's average diameter at 890 feet (270 meters) ± 200 feet (60m); the new Herschel observations returned a more precise diameter of 1,065 feet (325m) ± 50 feet (15m).
"The 20 percent increase in diameter from 890 feet (270m) to 1,065 feet (325m) translates into a 75 percent increase in our estimates of the asteroid's volume or mass," said Thomas Müller of the Max Planck Institute for Extraterrestrial Physics in Garching, Germany.
By analyzing the heat emitted by Apophis, Herschel also provided a new estimate of the asteroid's albedo — a measure of its reflectivity — of 0.23. This value means that 23 percent of the sunlight falling onto the asteroid is reflected; the rest is absorbed and heats up the asteroid. The previous albedo estimate for Apophis was 0.33.
Knowing the thermal properties of an asteroid indicates how its orbit might be altered due to subtle heating by the Sun. Known as the Yarkovsky effect — the heating and cooling cycle of a small body as it rotates and as its distance from the Sun changes — can instigate long-term changes to the asteroid's orbit.
"These numbers are first estimates based on the Herschel measurements alone, and other ongoing ground-based campaigns might produce additional pieces of information, which will allow us to improve our results," said Müller.
"Although Apophis initially caught public interest as a possible Earth impactor, which is now considered highly improbable for the foreseeable future, it is of considerable interest in its own right, and as an example of the class of near Earth objects," said Göran Pilbratt from ESA. "Our unique Herschel measurements play a key role for the physical characterization of Apophis, and will improve the long-term prediction of its orbit."
ExploringMarsBooklet_2
