Three telescopes — Chandra, ESA’s XMM-Newton, and NASA’s Rossi X-ray Timing Explorer (RXTE) — observed eight neutron stars, including one in 47 Tucanae, a globular cluster located some 15,000 light-years from Earth in the outskirts of the Milky Way. The image shown here was constructed from a long Chandra observation of 47 Tucanae. Lower-energy X-rays are red, X-rays with intermediate energies are green, and the highest-energy X-rays are shown in blue.
In the image, the double, or binary, star system labeled as X7 contains a neutron star slowly pulling gas away from a companion star with a mass much lower than the Sun. In 2006, researchers used observations of the amount of X-rays from X7 at different energies together with theoretical models to determine a relationship between the mass and the radius of the neutron star. They used a similar procedure for Chandra observations of a neutron star in another globular cluster, NGC 6397, and for two other neutron stars in clusters that ESA’s XMM-Newton observed.
Four other neutron stars RXTE observed were undergoing bursts of X-rays that caused their atmospheres to expand. By following the cooling of the star, scientists can calculate its surface area. Then, by folding in independent estimates of the distance to the neutron star, scientists were able to gather more information on the relationships between the masses and radii of these neutron stars.
Because the mass and radius of a neutron star are directly related to interactions between the particles in the interior of the star, the latest results give scientists new information about the inner workings of neutron stars.
The researchers used a wide range of different models for the structure of these collapsed objects and determined that the radius of a neutron star with a mass that is 1.4 times the mass of the Sun is between 6.5–8.0 miles (10.4–12.9 kilometers). They also estimated the density at the center of a neutron star was about 8 times that of nuclear matter found in Earth-like conditions. This translates into a pressure that is over ten trillion trillion times the pressure required for diamonds to form inside Earth.
The results apply whether the entire set of bursting sources, or the most extreme of the other sources, are removed from the sample. Previous studies have used smaller samples of neutron stars or have not accounted for as many uncertainties in using the models.
The new values for neutron stars’ structure should hold true even if matter composed of free quarks exists in the cores of the stars. Quarks are fundamental particles that combine to form protons and neutrons and are not usually found in isolation. Scientists have postulated that free quarks may exist inside the centers of neutron stars, but no firm evidence for this has ever been found.
The researchers also made an estimate of the distances between neutrons and protons in atomic nuclei here on Earth. A larger neutron star radius naturally implies that, on average, neutrons and protons in a heavy nucleus are farther apart. Their estimate is being compared with values from terrestrial experiments.
The neutron star observations also provided new information about the so-called “symmetry energy” for nuclear matter, which is the energy cost required to create a system with a different number of protons than neutrons. The symmetry energy is important for neutron stars because they contain almost 10 times as many neutrons as protons. It is also important for heavy atoms on Earth, like uranium, because they often have more neutrons than protons. The results show that the symmetry energy does not change much with density.
