Spacecraft capture an Earth-directed coronal mass ejection
The particles from ejections cannot travel through the atmosphere to harm humans on Earth, but they can affect electronic systems in satellites and on the ground.
By | Published: August 21, 2013 | Last updated on May 18, 2023
The SOHO LASCO C2 instrument captured this image of the Earth-directed CME. SOHO’s coronographs are able to take images of the solar corona by blocking the light coming directly from the Sun with an occulter disk. The location of the actual Sun is shown with an image taken by SDO. // ESA & NASA/SOHO, SDO
On August 20, 2013, at 4:24 a.m. EDT, the Sun erupted with an Earth-directed coronal mass ejection (CME), a solar phenomenon which can send billions of tons of particles into space that can reach Earth one to three days later. These particles cannot travel through the atmosphere to harm humans on Earth, but they can affect electronic systems in satellites and on the ground.
Experimental NASA research models, based on observations from NASA’s Solar Terrestrial Relations Observatory, show that the CME left the Sun at speeds of around 570 miles per second (920 km/s), which is a fairly typical speed for CMEs.
Earth-directed CMEs can cause a space weather phenomenon called a geomagnetic storm, which occurs when they funnel energy into Earth’s magnetic envelope, the magnetosphere, for an extended period of time. The CME’s magnetic fields peel back the outermost layers of Earth’s fields, changing their very shape. In the past, geomagnetic storms caused by CMEs of this strength have usually been mild.
Magnetic storms can degrade communication signals and cause unexpected electrical surges in power grids. They also can cause aurorae.
