Scientists find a low-density planet that won’t stick to a schedule
The exoplanets nearly eluded detection because of its highly inconsistent orbit time around its host star.
By | Published: November 3, 2014 | Last updated on May 18, 2023
Low density planet illustration
Illustration by Michael S. Helfenbein
For their latest discovery, Yale astronomers and the Planet Hunters program have found a low-mass, low-density planet with a punctuality problem.
The new planet, called PH3c, is located 2,300 light-years from Earth and has an atmosphere loaded with hydrogen and helium.
The elusive orb nearly avoided detection. This is because PH3c has a highly inconsistent orbit time around its sun due to the gravitational influence of other planets in its system. “On Earth, these effects are very small, only on the scale of one second or so,” said Joseph Schmitt from Yale University in New Haven, Connecticut. “PH3c’s orbital period changed by 10.5 hours in just 10 orbits.”
That inconsistency kept it from being picked up by automated computer algorithms that search stellar light curves and identify regular dips caused by objects passing in front of stars.
Luckily, Planet Hunters came to the rescue. The program, which has found more than 60 planet candidates since 2010, enlists citizen scientists to check survey data from the Kepler spacecraft. Planet Hunters recently unveiled a new website and an expanded scientific mission.
“It harnesses the human dimension of science,” said Debra Fischer from Yale. “Computers can’t find the unexpected, but people can when they eyeball the data.”
More than 300,000 volunteers are part of Planet Hunters, which is coordinated by Yale and the University of Oxford. The program’s revamped website will allow Planet Hunters to analyze data more quickly than before, Fischer said. In addition, Planet Hunters is launching an effort to see if there is a correlation between types of stars and the planets that form around them.
“I think we’ll be able to contribute some really unique science this way,” Fischer said.
Not only did Planet Hunters spot PH3c, but the discovery also enabled astronomers to better characterize two other planets — one on each side of PH3c. An outer planet, PH3d, is slightly larger and heavier than Saturn, for example. An inner planet, PH3b, may have a rocky composition like Earth.
“Finding the middle planet was key to confirming the others and allowing us to find their masses,” Schmitt said. “The outer planet’s orbital period also changes slightly, by about 10 minutes. You need to see both planets’ changing orbital periods in order to find out the masses of the planets. One planet doesn’t give enough information.”
There’s also a quirky aspect of the planetary trio, Schmitt added. The outer planet’s year is 1.91 times longer than the middle planet’s year, and the middle planet’s year is 1.91 times longer than the inner planet’s year.
“We’re not sure if this is just a coincidence or whether this might tell us something about how the planets were formed,” Schmitt said.
