Does dark matter cause mass extinctions and geologic upheavals?
A university professor concludes that movement through dark matter may perturb the orbits of comets and lead to additional heating in Earth's core, both of which could be connected with mass extinction events.
By | Published: February 23, 2015 | Last updated on May 18, 2023
NGC 4565
NGC 4565 is an edge-on spiral galaxy. The stars, dust, and gas are concentrated into a thin disk, much like the one in our Milky Way Galaxy.
Jschulman555
Research by New York University Biology Professor Michael Rampino concludes that Earth’s infrequent but predictable path around and through our galaxy’s disk may have a direct and significant effect on geological and biological phenomena occurring on Earth. In a new paper, he concludes that movement through dark matter may perturb the orbits of comets and lead to additional heating in the Earth’s core, both of which could be connected with mass extinction events.
The galactic disk is the region of the Milky Way Galaxy where our solar system resides. It is crowded with stars and clouds of gas and dust and also a concentration of elusive dark matter — small subatomic particles that can be detected only by their gravitational effects.
Previous studies have shown that Earth rotates around the disk-shaped galaxy once every 250 million years. But Earth’s path around the galaxy is wavy, with the Sun and planets weaving through the crowded disk approximately every 30 million years. Analyzing the pattern of Earth’s passes through the galactic disk, Rampino notes that these disk passages seem to correlate with times of comet impacts and mass extinctions of life. The famous comet strike 66 million years ago that led to the extinction of the dinosaurs is just one example.
What causes this correlation between Earth’s passes through the galactic disk and the impacts and extinctions that seem to follow?
While traveling through the disk, the dark matter concentrated there disturbs the pathways of comets typically orbiting far from Earth in the outer solar system, Rampino observes. This means that comets that would normally travel at great distances from Earth instead take unusual paths, causing some of them to collide with the planet.
But even more remarkably, with each dip through the disk, the dark matter can apparently accumulate within Earth’s core. Eventually, the dark matter particles annihilate each other, producing considerable heat. The heat created by the annihilation of dark matter in Earth’s core could trigger events such as volcanic eruptions, mountain building, magnetic field reversals, and changes in sea level, which also show peaks every 30 million years. Rampino therefore suggests that astrophysical phenomena derived from Earth’s winding path through the galactic disk and the consequent accumulation of dark matter in the planet’s interior can result in dramatic changes in Earth’s geological and biological activity.
His model of dark matter interactions with Earth as it cycles through the galaxy could have a broad impact on our understanding of the geological and biological development of Earth, as well as other planets within the galaxy.
Rampino said: “We are fortunate enough to live on a planet that is ideal for the development of complex life. But the history of the Earth is punctuated by large-scale extinction events, some of which we struggle to explain. It may be that dark matter — the nature of which is still unclear but which makes up around a quarter of the universe — holds the answer. As well as being important on the largest scales, dark matter may have a direct influence on life on Earth.”
In the future, he suggests, geologists might incorporate these astrophysical findings in order to better understand events that are now thought to result purely from causes inherent to Earth. This model, Rampino adds, likewise provides new knowledge of the possible distribution and behavior of dark matter within the galaxy.
