Simulations dispute dogma — rocky planets may orbit many double stars
Scientists believe non-gaseous planets are as prevalent around binaries as around single stars.
By | Published: April 3, 2015 | Last updated on May 18, 2023
Binary stars - double sunset
In this acrylic painting, University of Utah astrophysicist Ben Bromley envisions the view of a double sunset from an uninhabited Earthlike planet orbiting a pair of binary stars. In a new study, Bromley and Scott Kenyon of the Smithsonian Astrophysical Observatory performed mathematical analysis and simulations showing that it is possible for a rocky planet to form around binary stars, like Luke Skywalker’s home planet Tatooine in the “Star Wars” films. So far, NASA’s Kepler space telescope has found only gas-giant planets like Saturn or Neptune orbiting binary stars.
Ben Bromley, University of Utah
Luke Skywalker’s home in Star Wars is the desert planet Tatooine, with twin sunsets because it orbits two stars. So far, only uninhabitable gas giant planets have been identified circling such binary stars, and many researchers believe rocky planets cannot form there. Now, mathematical simulations show that Earth-like solid planets such as Tatooine likely exist and may be widespread.
“Tatooine sunsets may be common after all,” concluded the study by Ben Bromley of the University of Utah in Salt Lake City and Scott Kenyon of the Smithsonian Astrophysical Observatory in Cambridge, Massachusetts.
“Our main result is that outside a small region near a binary star — either rocky or gas giant — planet formation can proceed in much the same way as around a single star,” they said. “In our scenario, planets are as prevalent around binaries as around single stars.”
The title of the new study is “Planet Formation Around Binary Stars: Tatooine Made Easy,” but the paper looks anything but easy. It is filled with mathematical formulas describing how binary stars can be orbited by planetesimals — asteroid-sized rocks that clump together to form planets.
“We took our sweet numerical time to show that the ride around a pair of stars can be just as smooth as around one,” when it comes to the early steps of planet formation, Bromley said. “The ‘made easy’ part is really saying the same recipe that works around the Sun will work around Tatooine’s host stars.”
The study was funded by NASA’s Outer Planets Program and was a spinoff of Bromley’s and Kenyon’s research into how dwarf planet Pluto and its major moon Charon act like a binary system. Both are orbited by four other moons.
Planets form like dust bunnies
From a swirling disk of gas and dust surrounding a young star, “planets form like dust bunnies under your bed, glomming together to make larger and larger objects,” said Kenyon, whose observatory is part of the Harvard-Smithsonian Center for Astrophysics. “When planets form around a binary, the binary scrambles up the dust bunnies unless they are on just the right orbit.”
Scientists call that a “most circular orbit,” which in reality is a not quite circular, oval-shaped orbit in which the entire oval has numerous little waves in it, Bromley said.
“It’s an oval with ripples,” which are caused by the cyclic tugging of the two central stars, he added.
“For over a decade, astrophysicists believed that planets like Earth could not form around most binary stars, at least not close enough to support life,” Bromley said. “The problem is that planetesimals need to merge gently together to grow. Around a single star, planetesimals tend to follow circular paths — concentric rings that do not cross. If planetesimals do approach each other, they can merge together gently.”
But if planetesimals orbit a pair of stars, “their paths get mixed up by the to-and-fro pull of the binary stars,” Bromley said. “Their orbits can get so tangled that they cross each other’s paths at high speeds, dooming them to destructive collisions, not growth.”
Previous research started with circular orbits when pondering planet formation around binary stars, Bromley said, while the new study shows that “planets, when they are small, will naturally seek these oval orbits and never start off on circular ones. If the planetesimals are in an oval-shaped orbit instead of a circle, their orbits can be nested, and they won’t bash into each other. They can find orbits where planets can form.”
In their study, Bromley and Kenyon showed mathematically and by simple computer simulations that rocky Earth-sized planets can form around binary stars if they have the oval “most circular” orbit. They didn’t conduct their simulations to the point of planet formation but showed that planetesimals could survive without collisions for tens of thousands of years in concentric oval-shaped orbits around binary stars.
“We are saying you can set the stage to make these things,” Bromley said. “It is just as easy to make an Earth-like planet around a binary star as it is around a single star like our Sun. So we think that Tatooines may be common in the universe.”
Kepler and worlds discovered
NASA’s Kepler space telescope has discovered more than 1,000 planets orbiting other stars, including some rocky planets in the so-called habitable zone neither too near and hot, nor too far and cold from the star they each orbit.
So far, Kepler has found seven planets orbiting within or near the habitable zone around binary stars, but all of them are giant gaseous planets, Bromley said.
“The planets that Kepler has discovered so far around binary stars are larger, Neptune- or Jupiter-sized gas giants,” he said. “None of those found so far are small and rocky like our Earth — or like Tatooine in Star Wars.”
Bromley believes Kepler hasn’t yet spotted Earth-like planets around binary stars because they are small compared with gas giants, “so it’s a hard measurement.”
While Kepler has found other gas giants farther from binary stars, there has been debate about how the seven in the habitable zone got where they are.
The new study shows it is possible they formed in place from gas and dust — something “everyone else says is impossible,” Bromley said. He also doubts it because there doesn’t appear to have been enough gas and dust for gas giants Kepler has spotted near binaries to have formed in place. The study also showed that the gas and dust could have moved in from elsewhere so the gas giants could form where they now are seen.
The prevailing theories contend the gas giants discovered by the Kepler spacecraft must have formed farther out in a cooler, calmer part of space and then migrated closer to the binary stars, either by spiraling inward though a disk of gas surrounding the binary pair or by being hurled in by the gravity of another more distant gas-giant planet.
But “an Earth-like Tatooine would have no problem forming right where it needs to be to host life,” Bromley said.
