Temporary lakes once filled and refilled across Mars’ surface
Ephemeral lakes once dotted the Red Planet's giant Hellas impact basin.
By | Published: November 5, 2018 | Last updated on May 18, 2023
hellas1
A color image of the Hellas Planitia region of Mars.
NASA/JPL/USGS
Today, water on Mars is locked in ice deposits or held in deep underground lakes. But water once flowed across the planet’s surface, and researchers have found further evidence of its presence on the Red Planet.
A new study reveals that the Hellas impact basin on Mars once contained a number of ephemeral lakes, or lakes that are usually dry but fill up with water for brief periods of time.
Watery World
Located in the Red Planet’s southern hemisphere, the Hellas impact basin’s northeastern rim had many of these temporary lakes throughout Mars’ history, say researchers from the SETI Institute. The depressions were filled with water from a variety of sources, they say, including groundwater, snowfall, rivers and streams.
Known as paleolakes, these ancient martian lakes were active when Mars’ climate was drastically different than it is today. One of the paleolakes is almost completely filled with smooth sediment, the researchers found, which is similar to what scientists have seen in the saline lakes in the Andes mountains. This similarity suggests that the conditions on Mars when this paleolake formed could have been like the conditions in the Andes mountains today — cold and arid.
The paleolakes were found along water drainage systems that led to smaller depressions in the surface, or “lakes,” at the edge of Hellas Planitia, a plain within the impact basin. The lakes weren’t all the same, either. Some may have served as the source for channel systems hundreds of miles long, while other may have had rivers flowing through them. Still others bear the scars of likely flash floods.
“In the highest resolution images, we could see sediments, deposits, and what looked to be shorelines in some cases in these craters and depressions that the channels flowed into,” Virginia C. Gulick, a SETI senior research scientist and study researcher, said in an email.
marslakes1
An illustration showing when the paleolakes on Mars were active and how that compares to activity on early Earth.
Virginia C. Gulick
The team was surprised by their findings. “We were finding that these channels were active periodically through Mars’ history and much more recently than previously thought. They were active periodically from the late Noachian through the Hesperian through the late Amazonian,” Gulick said. Those time periods span billions of years, reaching to very near the present day, and indicate that such hydrological features were a common and long-lasting on the martian surface.
This research could be important in the search for life, potentially providing evidence for past microbial life on the planet. “Areas where water was periodically available over long periods of Mars’ history, especially if they were associated with volcanic magma hydrothermal systems, could have provided the habitats suitable for microbial life if it ever arose,” Gulick said.
This new study was published October 30 in the journal Astrobiology Volume 18, Number 11.
