Comet Halley begins showering Earth with Eta Aquariid meteors
Although the comet itself is still far from Earth, eons's worth of its ejected debris will lead to one of this year's best meteor showers.
By and | Published: April 29, 2019 | Last updated on May 18, 2023
comethalley
Comet 1P/Halley is perhaps the most famous comet. Though it only passes near Earth about once every 75 years, over time, it has left an expansive trail of debris throughout its entire orbital path. When Earth passes through this debris each year, we are treated to a meteor shower known as the Eta Aquariids.
NASA
While the Lyrid meteor shower is currently winding down, one of this year’s best meteor showers — the Eta Aquariids — is ramping up for its peak next week.
With New Moon arriving May 4, conditions couldn’t be better for the Eta Aquariid meteor shower, which peaks on the morning of May 6. Thankfully, the dwindling Moon casts less and less light into the morning sky as this week progresses, so observing conditions will continue to improve by the shower’s peak next Monday, leading to a particularly great display.
EtaAquariidsMay2019
The Eta Aquariids appear to radiate from the constellation Aquarius the Water-bearer. From mid-northern latitudes, this constellation rises near 2:30 a.m. local daylight time and climbs 25° high by twilight’s start.
The meteors derive from dust ejected by Comet 1P/Halley during its many trips around the Sun. Although this famous comet currently lies about as far from the Sun as it can, debris from its many encounters with the Sun fills in its orbital path. When Earth plows through this stream of detritus, our planet’s atmosphere incinerates the tiny dust particles, creating streaks of light we called meteors, or “shooting stars.”
This week, the best views will come in the hour or two before morning twilight commences, when you might see 5 to 10 meteors per hour from a dark site. However, during the shower’s peak early on May 6, Northern Hemisphere observers could see up to 20 meteors per hour under dark skies.
Viewers in the Southern Hemisphere, where the shower’s radiant passes nearly overhead, should see twice as many. And with the Moon having reached its New phase the night before, we couldn’t ask for better conditions.
For more quick and easy observing tips, check out The sky this week for April 26 to May 5.
