From the July 2019 issue
What Will Happen to the Sun?
The Sun will consume Mercury and Venus — and maybe Earth, too.
StellarCorpse
STELLAR CORPSE. After the Sun’s death, much of its matter will dissipate as a planetary nebula, a slowly expanding bubble of gas. The Helix Nebula in Aquarius represents one of the sky’s most beautiful such objects.
NASA/ESA/C. R. O’Dell, M. Meixner, and P. McCullough
The Sun is an ordinary star. It bathes the solar system with light and heat, making life possible on Earth. It’s as regular as clockwork, and it sets our daily life cycles in conjunction with Earth’s spin. Little wonder ancient peoples revered the Sun as a god. Yet the Sun will not always be steady and reliable. Billions of years from now, the Sun’s finale will turn Earth — and the entire inner solar system — into a very nasty place.
At 4.6 billion years old, the Sun is about halfway through its life. Its adulthood, called the main sequence phase, lasts 10 billion years. When the Sun runs out of hydrogen fuel, it must generate energy by fusing heavier elements.
At that point, its main sequence phase is over. In one of the most peculiar transformations we know of, the Sun’s helium core, about the size of a giant planet, will contract and heat up. And, in response, the Sun will expand by 100 times.
SolarPortrait
SOLAR PORTRAIT. An image of the Sun from the NASA/ESA Solar and Heliospheric Observatory (SOHO) reveals complex features visible uniquely at each wavelength.
NASA/ESA/SOHO
The swollen Sun will consume the planets Mercury and Venus — and possibly Earth as well. Astronomers watching from another solar system would classify this bloated version of our Sun as a red giant.
With the Sun’s transformation into a red giant come new types of fusion reactions. An outer shell will fuse hydrogen as the byproducts fall inward, further compressing and heating the core. When the core reaches 180 million degrees F (100 million degrees C), its helium will ignite and begin to fuse into carbon and oxygen.
The Sun will shrink somewhat, but, after a time, and for 100 million years, it will again expand. It will then brighten significantly as it plunges toward the end of its helium-burning phase, when vigorous outflows called stellar winds strip the Sun’s outer layers. This will lead to the Sun’s final life phase — a cyclical, gentle shedding of gas into what astronomers call a planetary nebula.
BigStorm
BIG STORM. An enormous, handle-shaped prominence juts from the Sun’s disk in this September 14, 1999, SOHO image. Prominences are huge clouds of cool, dense plasma suspended in the Sun’s outermost atmosphere.
NASA/ESA/SOHO
As the swollen Sun incinerates the solar system’s inner planets, its outer icy worlds will melt and transform into oases of water for tens or hundreds of millions of years. “Our solar system will then harbor not one world with surface oceans,” says astronomer S. Alan Stern of NASA’s Science MIssion Directorate, “but hundreds — all the icy moons of the gas giants, as well as the icy dwarf planets of the Kuiper Belt.” Pluto’s temperature, says Stern, will resemble that of Miami Beach.
A question Stern and other planetary scientists are asking: Will the outer worlds with newfound water evolve life in the relatively brief intervals they have to do so? The liquid water on these worlds might exist for only a few hundred million years. After that, the Sun’s luminosity will dim to the point where these new water worlds will permanently refreeze. Hydrocarbons that could contribute to life’s emergence are already there, though. So, it’s possible that, in its death throes, our Sun may seed new life.
Some 10 billion red giants blaze today in the Milky Way Galaxy. Among all of these aged stars, might some have spawned new life on worlds that remained frozen during the stars’ main sequence phases? It’s possible, say astronomers, but only time — and a whole lot more research — will tell.
