The constellation Coma Berenices (pronounced KOE-muh-bear-uh-NYE-seez), Berenice’s Hair, was envisioned in its current form by Flemish cartographer Gerardus Mercator. To honor Queen Berenice II of Egypt, he placed these stellar locks on a celestial globe he designed in 1551. Unfortunately, Coma Berenices, which contains no bright stars, is not an easy star pattern to find. It’s visible only from midwinter through midsummer in the Northern Hemisphere. Its center lies at right ascension 12h45m and declination 23°30'.
Coma Berenices ranks 42nd in size out of the 88 constellations, covering 386.47 square degrees (0.937 percent) of the sky. And while its size is middling, it fares worse (57th) in terms of overall brightness.
The best date to see Coma Berenices is April 2, when it stands opposite the Sun in the sky and reaches its highest point at local midnight. The constellation is completely visible from latitudes north of 56° south, and it remains entirely invisible only between latitude 77° south and the South Celestial Pole.
Although this star pattern isn’t particularly expansive or bright, it contains no less than eight Messier objects, the third most of any constellation. You’ll also find lots of other worthy targets tangled up in Berenice’s Hair. Let your telescope adjust to the outside temperature, get comfortable, and spend an enjoyable night combing through the great deep-sky objects in Coma Berenices. Good luck
