Venus Express is up and away
Europe's first mission to Venus is en route.
By | Published: November 9, 2005 | Last updated on May 18, 2023
November 9, 2005; updated November 14
A 12-year hiatus in Venus exploration ended Tuesday night with the European Space Agency’s (ESA) launch of Venus Express. At 10:33 p.m. EST, the Soyuz-Fregat rocket carrying the spacecraft lifted off from Kazakhstan’s Baikonur Cosmodrome. Eighty-two minutes later, the Fregat upper stage burned a second time and sent Venus Express into an escape trajectory that will deliver it to Venus in April 2006.
Venus outshines everything in the sky except the Sun and Moon. It’s Earth’s closest planetary neighbor and orbits the Sun about 30-percent closer. When Venus passes between Earth and the Sun, the planet lies about 26 million miles (42 million kilometers) away — roughly 100 times farther than our own Moon.
Venus Express is the first probe dedicated to studying our neighbor planet since NASA’s radar-mapping Magellan mission launched in 1989. Magellan peered through Venus’ clouds, using radio waves to map 98 percent of the planet at high resolution, revealing impact craters, rift valleys, and volcanoes. It burned up in the planet’s atmosphere in late 1994. Venus Express, ESA’s first Venus mission, instead will focus on the planet’s peculiar atmosphere.
Venus Express blasts off
The Soyuz-Fregat rocket carrying Venus Express blasted off from Baikonur’s launch pad 6 November 9 (local time).
ESA / Starsem
Veiled planet
A thick mantle of clouds shrouds Venus and hid its true character until the 1950s. Until then, astronomers thought of Venus as Earth’s twin based on similarities like size, mass, and distance from the Sun.
ESA / Starsem
But Venus turns out to be a grotesque parody of Earth. Its perpetual clouds are made not of water, but droplets of sulfuric acid. Carbon dioxide makes up most of the atmosphere, which is so dense, the pressure it exerts on the planet’s surface is more than 90 times what we experience on Earth. This is the same pressure a submarine would experience nearly 3,000 feet (900 meters) beneath the sea. the Russian Venera spacecraft successfully landed on the planet’s surface in the 1970s and 1980s, but they didn’t survive long.
Venus has no oceans, lakes, rivers, or rainfall. The planet’s high surface temperature — a constant 870° Fahrenheit (465° Celsius), or nearly twice the temperature of an oven’s broiler — prevents any liquid water. In fact, Venus is 100,000 times drier than the driest place on Earth. Call it global warming gone wild. The thick carbon-dioxide atmosphere lowers the planet’s ability to radiate heat into space, so the temperature rises.
Yet scientists think Venus may once have held oceans, just like Earth, and they’d like to understand why the two worlds are so dissimilar now.
Venus or bust
Existing meteorological models fail to reproduce the venusian atmosphere’s behavior. For example, clouds at the equator circle the planet in just 4 days. Several spacecraft have seen hints of lightning in the atmosphere, but definitive evidence has yet to be found.
Although scientists have identified sulfuric acid droplets in the upper cloud deck, spacecraft passing through lower clouds suggest the presence of crystalline particles, not droplets. If so, their chemical makeup must be more exotic than sulfuric acid.
Path to Venus
This plot illustrates Venus Express’ course (red, tick marks at 10-day intervals) between Earth (blue) and Venus (brown). The paths the planets travel between the spacecraft’s launch and its arrival at Venus are also shown. The black ellipse indicates Mercury’s orbit.
ESA
The spacecraft’s Venus Mapping Camera will be the first to study the planet at wavelengths across the spectrum, from the infrared to the ultraviolet. It will even be able to look for hot spots on the surface possibly caused by erupting volcanoes. Although the Venus Mapping Camera was developed for Venus Express, most of the instruments were built out of flight-qualified spares from two previous ESA missions — Mars Express and Rosetta.
Venus Express will cruise through space for 153 days. When captured by Venus’ gravity, the spacecraft will adjust its orbit over a period of 5 days, eventually looping around the planet’s poles. At its closest, it will reach an altitude of 155 miles (250 km) above the planet’s high northern latitudes. At its farthest, it will be 41,000 miles (66,000 km) above the planet’s southern hemisphere.
Mission planners expect the mapping mission to last 500 Earth days, but Venus Express carries enough fuel to maintain its polar orbit twice this long.
ESA postponed the launch, originally scheduled for October 26, when pieces of insulating material from the launcher’s Fregat upper stage were found to have contaminated the spacecraft. Fortunately, the pieces were easy to identify by eye or with the help of ultraviolet lamps. Technicians carefully removed the particles using tweezers, vacuum cleaners, or nitrogen-gas airbrushes.
