A cluster with a secret
A recent survey of the stars in globular cluster M4 has uncovered one sun with more lithium than expected.
By | Published: September 5, 2012 | Last updated on May 18, 2023
M4_star
This image from the Wide Field Imager attached to the MPG/ESO 2.2-meter telescope at ESO’s La Silla Observatory shows the spectacular globular star cluster Messier 4. This great ball of ancient stars is one of the closest of such stellar systems to the Earth. New observations with ESO’s Very Large Telescope have revealed that one star — marked on this picture — has much more lithium than the other stars in the cluster that have been studied. The source of this lithium is mysterious. Normally this element is gradually destroyed over the billions of years of a star’s life.
ESO
A new image from the European Southern Observatory’s (ESO) La Silla Observatory in Chile shows the spectacular globular star cluster Messier 4. This ball of tens of thousands of ancient stars is one of the closest and most studied of the globular clusters, and recent work has revealed that one of its stars has strange and unexpected properties, apparently possessing the secret of eternal youth.
The Milky Way Galaxy is orbited by more than 150 globular star clusters that date back to the distant past of the universe. One of the closest to the Earth is the cluster M4 (also known as NGC 6121) in the constellation of Scorpius the Scorpion. This bright object can be easily seen in binoculars, close to the bright red star Antares, and a small amateur telescope can show some of its constituent stars.
This new image of the cluster from the Wide Field Imager (WFI) on the MPG/ESO 2.2-meter telescope at ESO’s La Silla Observatory reveals many more of the cluster’s tens of thousands of stars and shows the cluster against the rich background of the Milky Way.
Astronomers have also studied many of the stars in the cluster individually using instruments on ESO’s Very Large Telescope. By splitting the light from the stars up into its component colors they can work out their chemical composition and ages.
New results for the stars in M4 have been surprising. The stars in globular clusters are old and hence not expected to be rich in the heavier chemical elements. But in a recent survey, astronomers found that one the M4 stars has much more of the rare light element lithium than expected. The source of this lithium is mysterious. Normally, this element is gradually destroyed over the billions of years of a star’s life, but this one star among thousands seems to have the secret of eternal youth. It has either somehow managed to retain its original lithium, or it has found a way to enrich itself with freshly made lithium.
