Earth might have hairy dark matter
A new study proposes the existence of long filaments of dark matter, or “hairs.”
Earth surrounded by theoretical filaments of dark matter called "hairs."
This illustration shows Earth surrounded by theoretical filaments of dark matter called "hairs."
NASA/JPL-Caltech
The solar system might be a lot hairier than we thought.
Dark matter is an invisible, mysterious substance that makes up about 27 percent of all matter and energy in the universe. The regular matter, which makes up everything we can see around us, is only 5 percent of the universe. The rest is dark energy, a strange phenomenon associated with the acceleration of our expanding universe.
Neither dark matter nor dark energy has ever been directly detected, although many experiments are trying to unlock the mysteries of dark matter, whether from deep underground or in space.
Based on many observations of its gravitational pull in action, scientists are certain that dark matter exists, and they have measured how much of it there is in the universe to an accuracy of better than one percent. The leading theory is that dark matter is “cold,” meaning it doesn’t move around much, and it is “dark” insofar as it doesn’t produce or interact with light.
Galaxies, which contain stars made of ordinary matter, form because of fluctuations in the density of dark matter. Gravity acts as the glue that holds both the ordinary and dark matter together in galaxies.
According to calculations done in the 1990s and simulations performed in the last decade, dark matter forms “fine-grained streams” of particles that move at the same velocity and orbit galaxies such as ours.
“A stream can be much larger than the solar system itself, and there are many different streams crisscrossing our galactic neighborhood,” said Gary Prézeau of NASA’s Jet Propulsion Laboratory (JPL) in Pasadena, California.
Prézeau likens the formation of fine-grained streams of dark matter to mixing chocolate and vanilla ice cream. Swirl a scoop of each together a few times and you get a mixed pattern, but you can still see the individual colors.
“When gravity interacts with the cold dark matter gas during galaxy formation, all particles within a stream continue traveling at the same velocity,” Prézeau said.
But what happens when one of these streams approaches a planet such as Earth? Prézeau used computer simulations to find out.
His analysis found that when a dark matter stream goes through a planet, the stream particles focus into an ultra-dense filament, or “hair,” of dark matter. In fact, there should be many such hairs sprouting from Earth.
A stream of ordinary matter would not go through Earth and out the other side. But from the point of view of dark matter, Earth is no obstacle. According to Prézeau’s simulations, Earth’s gravity would focus and bend the stream of dark matter particles into a narrow dense hair.
Hairs emerging from planets have both “roots,” the densest concentration of dark matter particles in the hair, and “tips,” where the hair ends. When particles of a dark matter stream pass through Earth’s core, they focus at the “root” of a hair, where the density of the particles is about a billion times more than average. The root of such a hair should be around 600,000 miles (1 million kilometers) away from the surface, or twice as far as the Moon. The stream particles that graze Earth’s surface will form the tip of the hair, about twice as far from Earth as the hair’s root.
“If we could pinpoint the location of the root of these hairs, we could potentially send a probe there and get a bonanza of data about dark matter,” Prézeau said.
A stream passing through Jupiter’s core would produce even denser roots: almost 1 trillion times denser than the original stream, according to Prézeau’s simulations.
“Dark matter has eluded all attempts at direct detection for over 30 years. The roots of dark matter hairs would be an attractive place to look, given how dense they are thought to be,” said Charles Lawrence from JPL.
Another fascinating finding from these computer simulations is that the changes in density found inside our planet — from the inner core, to the outer core, to the mantle to the crust — would be reflected in the hairs. The hairs would have “kinks” in them that correspond to the transitions between the different layers of Earth.
Theoretically, if it were possible to obtain this information, scientists could use hairs of cold dark matter to map out the layers of any planetary body, and even infer the depths of oceans on icy moons.
Further study is needed to support these findings and unlock the mysteries of the nature of dark matter.
Apollo_RightRail
