Why are Uranus and Neptune different colors?
For years, astronomers have wondered why the otherwise near-identical ice giants are two different shades of blue. A new model may finally reveal the answer.
RELATED TOPICS: NEPTUNE | URANUS | PLANETARY ATMOSPHERES
noirlab2211a
NASA/JPL-Caltech/B. Jónsson
To the untrained eye, it might be difficult to immediately differentiate between Uranus and Neptune. Yes, the color of Uranus is often described as cyan, while the color of Neptune is frequently cited as azure. But no matter your nomenclature, it's hard to deny the ice giants look quite similar at a quick glance. And that's not entirely surprisingly when you consider that similar components make up both worlds.
For years, researchers have struggled to develop a model that accurately explains the slight color difference between Uranus and Neptune. But now, scientists believe they might have finally cracked the code to why our solar system's two most distant planets are slightly different shades of blue.
The new model suggests that while haze accumulates in the atmospheres of both planets, Uranus' sluggish atmosphere is bad at dispelling that haze, giving it a slightly lighter shade of blue than Neptune. The results were published May 23 in the Journal of Geophysical Research: Planets
The true twins of the solar system
While Venus is often called Earth's sister world, the two rocky planets are a far cry from twins. Uranus and Neptune, on the other hand, are incredibly similar.
ASYIG1220_14vs3
Uranus is home to 13 known rings and 27 moons. Neptune has just five rings and 14 moons, the most famous of which is Triton.
Astronomy: Roen Kelly
For starters, Neptune and Uranus are basically the same size: Both worlds are just over 30,000 miles (50,000 kilometers) wide, and Uranus is only a measly 900 miles (1,500 kilometers) larger in diameter than Neptune. Their masses are also about the same: Uranus is some 14 times the mass of Earth, while Neptune is about 17 times the mass of Earth.
Being ice giants, both planets are primarily composed of elements heavier than hydrogen and helium, such as oxygen, carbon, nitrogen, and sulfur. Although the tippy-tops of both worlds’ atmospheres are predominately hydrogen, helium, and methane, their mantles are chock-full of water, ammonia, and (again) methane.
From their sizes to their masses to their atmospheric compositions, the solar system’s ice giants share many properties with one another. So, it’s no surprise that their differing color schemes have long left astronomers scratching their heads.
Modeling shades of blue
Although the ice giants' compositions are nearly the same, the new research describes how Uranus has more haze in its upper atmosphere than Neptune does, which gives Uranus a slightly whiter tint. According to the new model, if neither planet had any such haze, they would be almost exactly same shade of blue.
Unlike past models, the new model looked at the ice giants through a wide range of wavelengths, corresponding to numerous atmospheric layers. It also moved the haze particles deeper into the planets’ clouds, which, before now, researchers thought was a region that only contained layers of methane and hydrogen sulfide ices.
STScI01EVSSSN6T0YKZSDTPNHEXDEP2
Hubble captured two dark spots on Neptune in January 2020. A few months later, the smaller of the two storms had disappeared.
NASA, ESA, STScI, M.H. Wong (University of California, Berkeley) and L.A. Sromovsky and P.M. Fry (University of Wisconsin-Madison)
Both Uranus and Neptune are thought to condense methane ice in their hazy upper clouds, with the methane falling  to deeper layers of their atmospheres as snow. However, Neptune’s more active atmosphere means this methane snow falls more efficiently than it does on Uranus, giving it a bolder blue color than its twin.
The model doesn’t just stop at the haze, either. It also explains Neptune’s aptitude for developing dark spots. Like Jupiter’s Great Red Spot, researchers believe that these enormous spots are likely storms in Neptune’s — and occasionally Uranus’ — lower atmosphere. According to the latest model, either a darkening or clearing of the deepest layer of haze could be responsible for creating these shadowy features.
While the new model is promising, it doesn't hold all the answers to the mysteries of these distant giants
The first and last time a spacecraft visited our solar system's most distant planets was Voyager 2 in the 1980s. Ever since, scientists have been clamoring to return. And now that Uranus was recently labeled as one of the priorities for NASA in the next decade, odds are good for a future mission that will unlock the secrets of the ice giants.
Apollo_RightRail
