From the October 2006 issue
Glenn Chaple’s observing basics: A dumbell for you
October 2006: The Dumbbell Nebula it's the brightest and easiest-to-observe of all planetary nebulae.
By | Published: October 1, 2006 | Last updated on June 7, 2023
M27
The Dumbbell Nebula is a popular target for astro imagers.
Mike Fuller
Hey, everybody, I was joking! Last month, I suggested that the Dumbbell Nebula was named after me. Some readers believed the story — well, at least those who know me.
Let me set the record straight. Any similarity between the nickname of a certain planetary nebula in the constellation Vulpecula and yours truly is purely coincidental.
Even though it wasn’t named for me, the Dumbbell Nebula is one of my favorite deep-sky objects. Also known by the Messier designation M27, it’s the brightest and easiest-to-observe of all planetary nebulae. Only the Ring Nebula (M57), which is smaller and fainter — but much easier to locate — attracts more attention.
Planetary nebulae are a particularly fascinating class of deep-space object. The death throes of an average-size star, like our Sun, create these cosmic puffballs. As the ailing star’s core switches from hydrogen to helium fuel, it sheds its outer layers in an expanding shell of gas. The shell’s spherical shape gives the typical planetary nebula its planet-like appearance.
Planetary nebulae fade away faster than the emission and reflection nebulae that give birth to stars. While the latter survive for millions of years, a planetary nebula’s gases dissipate into the blackness of interstellar space after a few thousand years.
Finding M27 can be a challenge even for the experienced skygazer. Its parent constellation, Vulpecula the Fox, contains no bright naked-eye stars. To find M27, trace a line from Gamma (γ) Lyrae through Beta (β) Cygni, and then extend it an equal distance beyond.
Or, if you can find the constellation Sagitta, you can take a more direct route to M27 by aiming toward Gamma Sagittae and then moving about 3° northward. Under a dark sky, binoculars and finder scopes will pick up M27 as a small smudge of light close to the star 14 Vulpeculae. A low-power eyepiece can sweep up M27 because of the nebula’s relatively large size (8′ by 5′) and brightness (magnitude 7.3). Once you’ve found it, switch to higher power. The Dumbbell is a remarkable sight at magnifications of 100x or more.
Finding M27
Do’t let trying to find the Dumbbell Nebula, M27, leave you dumbfounded. This finder chart can help you find the sometimes elusive, but always-impressive, target.
Astronomy: Roen Kelly
M27 has delighted and mystified observers since Charles Messier discovered it in 1764. Small telescopes show it as a rectangle with rounded edges. Its dumbbell shape — also described as an hourglass, bow tie, or apple core — is visible in medium- to large-aperture instruments. Apertures of 10 inches or larger (6- to 8-inch scopes in dark-sky locales) will reveal faint, pointed nebulosities extending from the Dumbbell’s long sides. With an Oxygen-III filter attached to an eyepiece to enhance subtle detail, my 13-inch Dobsonian turned the Dumbbell Nebula into the “Football Nebula.”
Any planetary nebula’s central star can be a challenge to see because it’s a faint white dwarf immersed in nebulosity. I’ve glimpsed M27’s central star in my 13-inch using a moderately high magnification (175x), and I suspect it can be viewed with an 8-inch scope under favorable conditions. If you have trouble seeing the central star, try averted vision. Here’s a trick to see faint stars and nebulous detail: Concentrate your gaze to the side of your target. The light then falls on a more sensitive part of the retina, revealing detail not normally visible with a direct view.
What I find most fascinating about the Dumbbell is the 3-D illusion it presents when viewed through a telescope. The Dumbbell seems to hover in the foreground against the backdrop of Milky Way stars.
If you’ve never seen M27, put it on your observing list for the next clear, moonless night. If you’ve already notched it with your telescope, don’t assume a “been there, done that” attitude. Like a fine painting, M27 shows something new each time you study it. This dumbbell will be giving the Dumbbell Nebula some serious attention during the months ahead. Why not join me?
Questions or comments? E-mail me here. Next month: a look at the “Demon Star.” Clear skies!
