NASA releases first interactive mosaic of lunar north pole
Scientists have created the largest high-resolution mosaic of our Moon’s north polar region.
By | Published: March 19, 2014 | Last updated on May 18, 2023
Moonmosaic
A new interactive mosaic from NASA’s Lunar Reconnaissance Orbiter covers the north pole of the moon from 60 to 90 degrees north latitude at a resolution of 6.5 feet (2 meters) per pixel. Close-ups of Thales crater (right side) zoom in to reveal increasing levels of detail.
NASA/Goddard/Arizona State University
Scientists, using cameras aboard NASA’s Lunar Reconnaissance Orbiter (LRO), have created the largest high-resolution mosaic of our Moon’s north polar region. The 6.5-feet-per-pixel (2 meters per pixel) images cover an area equal to more than one quarter of the United States.
Web viewers can zoom in and out and pan around an area. Constructed from 10,581 pictures, the mosaic provides enough detail to see textures and subtle shading of the lunar terrain. Consistent lighting throughout the images makes it easy to compare different regions.
“This unique image is a tremendous resource for scientists and the public alike,” said John Keller from NASA’s Goddard Space Flight Center in Greenbelt, Maryland. “It’s the latest example of the exciting insights and data products LRO has been providing for nearly five years.”
The images making up the mosaic were taken by the two LRO Narrow Angle Cameras, which are part of the instrument suite known as the Lunar Reconnaissance Orbiter Camera (LROC). The cameras can record a tremendous dynamic range of lit and shadowed areas.
“Creation of this giant mosaic took four years and a huge team effort across the LRO project,” said Mark Robinson from Arizona State University in Tempe. “We now have a nearly uniform map to unravel key science questions and find the best landing spots for future exploration.”
The entire image measures 931,070 pixels square — nearly 867 billion pixels total. A complete printout at 300 dots per inch — considered crisp resolution for printed publications — would require a square sheet of paper wider than a professional U.S. football field and almost as long. If the complete mosaic were processed as a single file, it would require approximately 3.3 terabytes of storage space. Instead, the processed mosaic was divided into millions of small compressed files, making it manageable for users to view and navigate around the image using a Web browser.
LRO entered lunar orbit in June 2009 equipped with seven instrument suites to map the surface, probe the radiation environment, investigate water and key mineral resources, and gather geological clues about the Moon’s evolution.
Researchers used additional information about the Moon’s topography from LRO’s Lunar Orbiter Laser Altimeter, as well as gravity information from NASA’s Gravity Recovery and Interior Laboratory (GRAIL) mission, to assemble the mosaic. Launched in September 2011, the GRAIL mission, employing twin spacecraft named Ebb and Flow, generated a gravity field map of the Moon — the highest resolution gravity field map of any celestial body.
You can access the map at http://lroc.sese.asu.edu/gigapan.
