NASA’s SDO observes “Cinco de Mayo” solar flare
This burst of radiation was the most powerful so far this year and already has resulted in a radio blackout.
By | Published: May 6, 2015 | Last updated on May 18, 2023
May 5 solar flare
NASA/SDO/Wiessinger
NASA’s Solar Dynamics Observatory, which watches the Sun constantly, captured these images of a significant solar flare — as seen in the bright flash on the left — peaking at 6:11 p.m. EDT on May 5, 2015. Each image shows a different wavelength of extreme ultraviolet light that highlights a different temperature of material on the Sun. By comparing different images, scientists can better understand the movement of solar matter and energy during a flare. From left to right, the wavelengths are: visible light, 171 angstroms, 304 angstroms, 193 angstroms and 131 angstroms. Each wavelength has been colorized.
Solar flares are powerful bursts of radiation. Harmful radiation from a flare cannot pass through Earth’s atmosphere to physically affect humans on the ground, however — when intense enough — they can disturb the atmosphere in the layer where GPS and communications signals travel. This flare is classified as an X2.7-class flare. X-class denotes the most intense flares, while the number provides more information about its strength. An X2 is twice as intense as an X1, an X3 is three times as intense, and so on.
A 4 p.m. EDT, Slooh will be going live with views of the active Sun based on the May 5 flare being the year’s most powerful solar storm so far. This sudden increase in solar violence will produce effects ranging from stunning aurorae to radio blackouts. A radio blackout already occurred yesterday evening.
