From the September 2016 issue
Variable stars
By | Published: September 12, 2016 | Last updated on May 18, 2023
ErikaRix
Simply put, a variable star is one that changes brightness by any means. Backyard observers can estimate a variable star’s apparent magnitude as it rises and falls over the course of time and then plot the results as a light curve. Sketching the observations can help improve an observer’s ability to notice subtle variances in stellar magnitudes.
If you’re new to variable star observing, Delta (δ) Cephei makes a nice beginner’s choice. It’s the prototype of the Delta Cepheid class of variable stars that, due to helium instabilities in their inner layers, pulsate with periods proportional to their luminosity. This means that their intrinsic brightnesses — and therefore distances — can be calculated directly from the length of their pulsation cycles, making them ideal cosmic measuring sticks.
Located near the king’s head in the constellation Cepheus, Delta Cep forms a distinct triangle with Zeta (ζ) Cephei and Epsilon (ε) Cephei. Telescopically, the variable star has a pale yellow hue with a 7th-magnitude bluish companion 41″ farther south. It takes about 1½ days for Delta Cep to rise to magnitude 3.5 in brightness before it slowly fades back to 4.4 for the remainder of its 5.37-day variable period. You can estimate its brightness with either the naked eye or with binoculars by using Zeta Cep (magnitude 3.6) and Epsilon Cep (magnitude 4.2) for comparison. If you can, record your observations nightly over the five-day time span.
ASYAS1116_02_MuCep
The artist sketched Mu (μ) Cephei using a 12-inch f/4.5 Newtonian at 250x. He used graphite on white paper and then scanned and inverted the sketch using image-editing software. He added color after scanning the sketch. Both sketches have been oriented so that north is up and west to the right.
Ferenc Lovró
Gaze 6° west of Delta Cep to locate another pulsating variable star, Mu (μ) Cephei. This red supergiant is among the largest and brightest stars in our sky. Called Herschel’s Garnet Star, it appears visually as ruddy yellow or orange. Unlike the short, regular periods of Delta Cep, Mu Cep undergoes long, semi-regular periods of roughly 840 and 4,400 days, varying between magnitude 3.4 and 5.1 in brightness. Bear in mind that red stars like Mu Cep will appear brighter if you watch for an extended period of time. So estimate Mu Cephei’s magnitude with a quick glance rather than a prolonged stare. Due to the length of its variable periods, monthly observations will suffice.
While sketching the star field, be extra diligent when depicting star magnitudes. Reassess the stars in your drawing often, and adjust their magnitudes as needed from the brightest to the faintest. Be sure to include the date and time (accurate to the minute) of your estimation as well as a thoroughly written record of your observation.
ASYAS1116_01_DeltaCep
The author sketched Delta (δ) Cephei while using a 4-inch refractor on a German equatorial mount. She used an 8mm eyepiece with a 0.5-degree true field of view for a magnification of 125x. She created the sketch with a #2 graphite pencil and a 0.5mm mechanical pencil. She then scanned and inverted it in Photoshop, where she also added star color.
Erika Rix
Interested in contributing to science? The more information researchers can gather about the long-term behavior of variable stars, the better understanding they gain of stellar properties and cosmic evolution. With more than 150,000 variable stars cataloged so far, this is a growing branch of amateur astronomy. Professional astronomers encourage backyard observers to submit their variable star observations to entities like the American Association of Variable Star Observers (AAVSO) so that researchers can access the collected data.
Be sure to choose variable stars that are suited for your observing location, equipment, and schedule. Then settle in for a long-lasting, highly worthwhile project.
