What is the “Roche limit” and how is it defined?
The Roche limit was created to study Saturn’s rings, but it’s now useful in understanding the thousands of exoplanets being discovered by space telescopes.
By | Published: October 27, 2014 | Last updated on May 18, 2023
Astronomers think early in the solar system's history, objects passed within Saturn's Roche limit, and the planet tore apart those bodies.
Astronomers think early in the solar system’s history, objects passed within Saturn’s Roche limit, and the planet tore apart those bodies. That debris now orbits Saturn as its ring system.
NASA/JPL-Caltech/SSI
In my astronomy studies decades ago, we used the “Roche limit” to determine when a smaller body is too close to survive a larger object’s gravitational force. Do astronomers still use that term?
John Tubbs
El Paso, Texas
When there is a large difference in mass between two objects, such as between a star and a planet, the more massive object can exert a great deal of force on its companion. If this force is enough to overcome the internal forces holding the object together, eventually it will tear apart the companion. The companion, however, is safe as long as it doesn’t get too close, which is exactly what the Roche limit is describing. It is essentially the distance inside which the companion object will quite literally be ripped to shreds.
When Éduoard Roche came up with this theory in the late 1800s, it helped him explain Saturn’s rings. He thought their existence hinged upon small moons being torn apart to replenish these rings, a theory we still believe today. Outside our solar system, however, there was little practical use for this theory until the past 5–10 years. In that time, space satellites such as MOST, CoRoT, and especially Kepler have increased the number of known exoplanets from a handful to thousands. This means that there are now objects for which the application of the Roche limit can provide useful information. In fact, a paper came out just last year that uses this limit to provide constraints on a planet’s internal composition.
While the Roche limit is mainly useful when there is a large discrepancy in mass, there are more widely used related techniques in stellar astronomy such as Roche lobes and Roche potentials. Unlike the Roche limit, the Roche lobe describes an object’s sphere of influence when it is orbiting a companion, while the Roche potential describes the object’s shape. In the study of binary systems, where one star orbits another, these descriptions are invaluable to modeling and helping determine fundamental parameters such as mass and radius.
Herbert Pablo
University of Montreal, Canada
[Editor’s note: This article was updated Feb. 14, 2023.]
