A hybrid solar eclipse sends totality across Africa
Some observers in Africa will see the Moon darken the Sun’s disk November 3, while residents of the East Coast will see a partially blocked star.
By | Published: September 26, 2013 | Last updated on May 18, 2023
1998 total solar eclipse
A total solar eclipse similar to this one from 1998 occurs November 3, 2013, across equatorial Africa.
Joel K. Harris
Those in central Africa on November 3 will get a glimpse of a total solar eclipse, when the Moon lies between the Sun and Earth and blocks our star’s entire disk. Before totality occurs, the lineup’s path provides a partial eclipse to those in eastern North America.
Watch streaming video of the eclipse LIVE starting at 6:45 a.m. EST (11h45m UT) below thanks to SLOOH.com!
An eclipse occurs when the Sun, the Moon, and Earth align (in that order, with our satellite in the middle). If they do so while the Moon is closer than average to Earth, observers will witness a total eclipse. Sometimes, though, its location in its orbit makes the Moon farther away than normal at the time of an alignment. Its distance makes it appear smaller in the sky and prevents its shadow from covering the Sun’s whole disk. Thus, eclipse viewers will see a ring of sunlight, known as the “annulus,” in the sky during this “annular eclipse.”
The November 3 eclipse begins as an annular one. Just 15 seconds after the Moon’s shadow appears on the ground, though, Earth’s curvature moves that point of contact farther into the lunar shadow, creating a total eclipse as the path tracks eastward. The part of the eclipse that occurs near local noon — off the western African coast, in this case — lies close enough to the Moon that our satellite’s shadow completely covers the Sun and creates totality. Near the beginning of the path, though, the Moon is a little more distant and cannot block the whole Sun, leaving the annulus visible. This combination of annularity and totality is known as a “hybrid eclipse.” Just 5 percent of eclipses are hybrid, making this the rarest variety.
November 2013 total solar eclipse path
The central path of the November 3 eclipse begins in the Atlantic Ocean about 600 miles (373 kilometers) east of Jacksonville, Florida. Maximum eclipse occurs some 200 miles (124km) southwest of Liberia, where totality lasts 1 minute and 39 seconds. The Moon’s shadow later makes landfall, with viewers seeing ever-decreasing lengths of totality.
Astronomy: Roen Kelly
The eclipse path begins just off North America’s coast — some 600 miles (373 kilometers) east of Jacksonville, Florida — at sunrise November 3, meaning no one on land will see the annular eclipse. Still, in Boston, those who venture outside will see the Sun 63 percent blocked, while in Miami, 48 percent will be dark. The eclipse then sweeps over the Atlantic Ocean, reaching its maximum some 200 miles (124km) southwest of Liberia, where totality lasts 1 minute and 39 seconds.
After the lunar shadow makes landfall, the length of totality decreases as the eclipse path wanders from Gabon to Somalia. Those near but not on the path of totality can still view a partial eclipse.
Astronomy contributor Joel K. Harris considers November’s event exciting but warns it may not be the easiest eclipse to catch, given the dubious weather conditions in central Africa. “The odds are about 50/50 that if you elect to expend the time and money to travel to the event, you will catch some glimpse of it,” he says. Nonetheless, he remains hopeful. “Even after chasing 18 total eclipses in the past four decades, I still find myself getting excited — and nervous.”
Eclipse viewing tips
  • Don’t view this event without eye protection. Even during the annular phase, the Sun shines brightly enough to damage your retinas if you view it directly. Use only approved eclipse glasses, solar filters, or #14 welder’s glass.
  • Arrive at your viewing site an hour or more before the partial phases of the eclipse begin, especially if you want to photograph the event.
  • Once the Moon covers a large part of the Sun’s disk but before annularity or totality begins, take a look at your surroundings to see the effects of the eclipse, including the tiny solar crescents created by sunlight filtering through any nearby trees.
