From the June 2003 issue
Arm in motion
The arm of a Mars Exploration Rover can do a lot more than just reach out and touch something.
By | Published: June 3, 2003 | Last updated on May 18, 2023
Spirit's Arm
This image taken by the front hazard-identification camera on the Mars Exploration Rover Spirit, shows the rover’s robotic arm, or instrument deployment device. The arm was deployed from its stowed position beneath the “front porch” of the rover body on January 15, 2004.
NASA / JPL
The Mars Exploration Rover carries an armload of instruments designed to poke, image, and explore the surface of Mars. With a length similar to that of a human arm and significantly greater flexibility, the arm can position any of its four instruments on rocks or on calibration targets. Arm instruments include a Rock Abrasion Tool that acts like a small drill, two spectrometers that work together to determine the composition of rocks and soils, and a microscopic imager that allows up-close imaging of materials around the rover.
To make sure the arm and its equipment will perform on the martian surface, engineers working with NASA put the arm through a rigorous battery of tests. Along with drilling into a large number of rocks and taking sample images and spectra, the rover was asked to strut its stuff in a chamber that simulated martian conditions. With temperatures well below freezing and the air pressure sucked down to almost a vacuum, this thermal vacuum chamber helps engineers confirm that the rover and its arm won’t breakdown in extreme conditions.
Scientists and engineers have also found ways to experiment with the rover’s arm without moving a single joint. Using three-dimensional renderings of target objects, rover operators can simulate reaching out and touching something without risking a bad-approach with a real rover. This will be particularly useful when trying to reach into small spaces or when maneuvering around outcroppings. In case someone does send an off-target command, the arm’s instruments are equipped with auto-shutoff contact switches similar to those found on many garage doors.
Through testing, simulation, and careful design, scientists and engineers have all but guaranteed that great discoveries will come from the Mars Exploration Rovers and their arm-bound instruments.
