A stronomers have discovered a never-before-seen cosmic “train wreck” between giant galaxy clusters. NASA’s Chandra X-ray Observatory and optical telescopes revealed a dark matter core mostly devoid of galaxies that may pose problems for current theories of dark matter behavior.
“These results challenge our understanding of the way clusters merge,” said Dr. Andisheh Mahdavi of the University of Victoria in British Columbia. “Or, they possibly make us even reexamine the nature of dark matter itself.”
There are three main components to galaxy clusters: individual galaxies composed of billions of stars, hot gas in between the galaxies, and dark matter, a mysterious substance that dominates the cluster mass and can be detected only through its gravitational effects.
Optical telescopes can observe the starlight from the individual galaxies, and can infer the location of dark matter by its subtle light-bending effects on distant galaxies. X-ray telescopes like Chandra detect the multimillion-degree gas.
A popular theory of dark matter predicts that dark matter and galaxies should stay together, even during a violent collision, as observed in the case of the so-called Bullet Cluster. However, when the Chandra data of the galaxy cluster system known as Abell 520 was mapped along with the optical data from the Canada-France-Hawaii Telescope and Subaru Telescope atop Mauna Kea in Hawaii, a puzzling picture emerged. A dark matter core was found, which also contained hot gas but no bright galaxies.
“It blew us away that it looks like the galaxies are removed from the densest core of dark matter,” said Dr. Hendrik Hoekstra, also of University of Victoria. “This would be the first time we’ve seen such a thing and could be a huge test of our knowledge of how dark matter behaves.”
In addition to the dark matter core, a corresponding “light region” containing a group of galaxies with little or no dark matter was also detected. The dark matter appears to have separated from the galaxies.
“The observation of this group of galaxies that is almost devoid of dark matter flies in the face of our current understanding of the cosmos,” said Dr. Arif Babul of the University of Victoria. “Our standard model is that a bound group of galaxies like this should have a lot of dark matter. What does it mean that this one doesn’t?”
In the Bullet Cluster, known as 1E 0657-56, the hot gas is slowed down during the collision but the galaxies and dark matter appear to continue on unimpeded. In Abell 520, it appears that the galaxies were unimpeded by the collision, as expected, while a significant amount of dark matter has remained in the middle of the cluster along with the hot gas.
Mahdavi and his colleagues have two possible explanations for their findings, both of which are uncomfortable for prevailing theories. The first option is that the galaxies were separated from the dark matter through a complex set of gravitational “slingshots.” This explanation is problematic because computer simulations have not been able to produce slingshots that are nearly powerful enough to cause such a separation.
The second option is that dark matter is affected not only by gravity, but also by an as-yet-unknown interaction between dark matter particles. This exciting alternative would require new physics and could be difficult to reconcile with observations of other galaxies and galaxy clusters, such as the aforementioned Bullet Cluster.
In order to confirm and fully untangle the evidence for the Abell 520 dark matter core, the researchers have secured time for new data from Chandra plus the Hubble Space Telescope. With the additional observations, the team hopes to resolve the mystery surrounding this system.
