Doubling down with rare white dwarf systems
Astronomers have found two white dwarf binary systems that could evolve into sources of gravitational waves.
By and | Published: December 18, 2013 | Last updated on May 18, 2023
AM CVn illustration
AM CVn are a rare class of objects where one white dwarf is pulling material from a compact companion star, such as a second white dwarf. Chandra and optical telescopes were used to identify two systems of binary stars that will one day become AM CVn systems. As the orbit between these white dwarfs shrink, scientists predict ripples in space-time will be given off.
NASA/CXC/M.Weiss
In the middle of the 20th century, an unusual star was spotted in the constellation Canes Venatici the Hunting Dogs. Years later, astronomers determined that this object, dubbed AM Canum Venaticorum (AM CVn), was, in fact, two stars. These stars revolve around each other every 18 minutes and are predicted to generate gravitational waves — ripples in space-time predicted by Einstein.
The name AM CVn came to represent a new class of objects where one white dwarf star is pulling matter from another compact companion star, such as a second white dwarf — white dwarf stars are dense remains of Sun-like stars that have run out of fuel and collapsed to the size of Earth. The pairs of stars in AM CVn systems orbit each other extremely rapidly, whipping around one another in an hour, and in one case as quickly as five minutes. By contrast, the fastest-orbiting planet in our solar system, Mercury, orbits the Sun once every 88 days.
Despite being known for almost 50 years, the question has remained: Where do AM CVn systems come from? New X-ray and optical observations have begun to answer that with the discovery of the first known systems of double stars that astronomers think will evolve into AM CVn systems.
The two binary systems — known by their shortened names of J0751 and J1741 — were observed in X-rays by NASA’s Chandra X-ray Observatory and ESA’s XMM-Newton telescope. Observations at optical wavelengths were made using the McDonald Observatory’s 2.1-meter telescope in Texas and the Mt. John Observatory 1.0-meter telescopes in New Zealand.
The artist’s illustration depicts what these systems are like now and what may happen to them in the future. The top panel shows the current state of the binary that contains one white dwarf (on the right) with about one-fifth the mass of the Sun and another much heavier and more compact white dwarf about five or more times as massive — unlike Sun-like stars, heavier white dwarfs are smaller.
As the two white dwarfs orbit around each other, gravitational waves — ripples in space-time predicted by Einstein — will be given off, causing the orbit to become tighter. Eventually, the smaller heavier white dwarf will start pulling matter from the larger lighter one as shown in the middle panel, forming an AM CVn system. This process continues until so much matter accumulates on the more massive white dwarf that a thermonuclear explosion may occur in about 100 million years.
One possibility is that the thermonuclear explosion could destroy the larger white dwarf completely in what astronomers call a type Ia supernova — the type of supernova used to mark large distances across the universe by serving as so-called standard candles. However, it’s more likely that a thermonuclear explosion will occur only on the surface of the star, leaving it scarred but intact. The resulting outburst is likely to be about one-tenth the brightness of a type Ia supernova. Such outbursts have been named — somewhat tongue-in-cheek — as .Ia supernovae. Such .Ia outbursts have been observed in other galaxies, but J0751 and J1741 are the first binary stars known that can produce .Ia outbursts in the future.
The optical observations were critical in identifying the two white dwarfs in these systems and ascertaining their masses. The X-ray observations were needed to rule out the possibility that J0751 and J1741 contained neutron stars. A neutron star, which would disqualify it from being a possible parent to an AM CVn system, would give off strong X-ray emission due to its magnetic field and rapid rotation. Neither Chandra nor XMM-Newton detected any X-rays from these systems.
AM CVn systems are of interest to scientists because they are predicted to be sources of gravitational waves, as noted above. This is important because even though such waves have yet to be detected, many scientists and engineers are working on instruments that should be able to detect them in the near future. This will open a significant new observational window to the universe.
