Earth-like planets are right next door
Astronomers have found that 6 percent of red dwarf stars have habitable Earth-sized planets.
By | Published: February 6, 2013 | Last updated on May 18, 2023
Habitable-planet
This artist’s conception shows a hypothetical habitable planet with two moons orbiting a red dwarf star. Astronomers have found that 6 percent of all red dwarf stars have an Earth-sized planet in the habitable zone, which is warm enough for liquid water on the planet’s surface. Since red dwarf stars are so common, then statistically the closest Earth-like planet should be only 13 light-years away. // David A. Aguilar (CfA)
Using publicly available data from NASA’s Kepler space telescope, astronomers at the Harvard-Smithsonian Center for Astrophysics (CfA) in Cambridge, Massachusetts, have found that 6 percent of red dwarf stars have habitable Earth-sized planets. Since red dwarfs are the most common stars in our galaxy, the closest Earth-like planet could be just 13 light-years away.
“We thought we would have to search vast distances to find an Earth-like planet. Now, we realize another Earth is probably in our own backyard waiting to be spotted,” said Courtney Dressing from CfA.
Red dwarf stars are smaller, cooler, and fainter than our Sun. An average red dwarf is only one-third as large and one-thousandth as bright as the Sun. From Earth, no red dwarf is visible to the naked eye.
Despite their dimness, these stars are good places to look for Earth-like planets. Red dwarfs make up three out of every four stars in our galaxy for a total of at least 75 billion. The signal of a transiting planet is larger since the star itself is smaller, so an Earth-sized world blocks more of the star’s disk. And since a planet has to orbit a cool star closer in order to be in the habitable zone, it’s more likely to transit from our point of view.
Dressing culled the Kepler catalog of 158,000 target stars to identify all the red dwarfs. She then reanalyzed those stars to calculate more accurate sizes and temperatures. She found that almost all of those stars were smaller and cooler than previously thought.
Since the size of a transiting planet is determined relative to the star size, based on how much of the star’s disk the planet covers, shrinking the star shrinks the planet. And a cooler star will have a tighter habitable zone.
Dressing identified 95 planetary candidates orbiting red dwarf stars. This implied that at least 60 percent of such stars have planets smaller than Neptune. However, most weren’t quite the right size or temperature to be considered truly Earth-like. Three planetary candidates were both warm and approximately Earth-sized. Statistically, this means that 6 percent of all red dwarf stars should have an Earth-like planet.
“We now know the rate of occurrence of habitable planets around the most common stars in our galaxy,” said David Charbonneau from CfA. “That rate implies that it will be significantly easier to search for life beyond the solar system than we previously thought.”
Locating nearby Earth-like worlds may require a dedicated small space telescope or a large network of ground-based telescopes. Follow-up studies with instruments like the Giant Magellan Telescope and James Webb Space Telescope could tell scientists whether any warm, transiting planets have an atmosphere and further probe its chemistry.
Such a world would be different from our own. Orbiting so close to its star, the planet would probably be tidally locked. However, that doesn’t prohibit life since a reasonably thick atmosphere or deep ocean could transport heat around the planet. And while young red dwarf stars emit strong flares of ultraviolet light, an atmosphere could protect life on the planet’s surface. In fact, such stresses could help life evolve. “You don’t need an Earth clone to have life,” said Dressing.
Since red dwarf stars live much longer than Sun-like stars, this discovery raises the interesting possibility that life on such a planet would be much older and more evolved than life on Earth. “We might find an Earth that’s 10 billion years old,” said Charbonneau.
The three habitable-zone planetary candidates identified in this study are Kepler Object of Interest (KOI) 1422.02, which is 90 percent the size of Earth in a 20-day orbit; KOI 2626.01, 1.4 times the size of Earth in a 38-day orbit; and KOI 854.01, 1.7 times the size of Earth in a 56-day orbit. All three are located about 300 to 600 light-years away and orbit stars with temperatures between 5700° and 5900° Fahrenheit (3100° and 3300° Celsius). For comparison, our Sun’s surface is 10000° F (5500° C).
