Today’s news, which appears in the journal Nature, concerns the equivalence principle, which roughly says that falling objects should all fall the same way. It sounds obvious put that way, of course, but the idea that heavier objects should fall at the same rate as lighter objects (discounting air resistance) still surprises people. The idea is that gravity accelerates heavier objects faster, sure, but because they’re more massive it’s harder for them to accelerate, so the two effects cancel out.
Galileo famously (and likely apocryphally) demonstrated the principal by dropping lead balls of different weights off the Leaning Tower of Pisa and observing them hit the ground at the same time. Apollo 15 astronaut David Scott recreated it on the moon, dropping a feather and a hammer; the two indeed hit the ground at the same time. “How ‘bout that!” he says in reaction.
And that’s basically what astronomers have done today, just recreated that experiment once again. Only this time, instead of a hammer and feather, they used a pulsar and a white dwarf.
Three-Body Lab
Some 4200 light-years away in the constellation Taurus lies a triple star system named PSR J0337+1715. It consists of two white dwarfs, small stars just a fraction of the mass of our sun, and a much tinier, denser pulsar. The pulsar and one of the white dwarfs orbit each other closely, and the second white dwarf has a much bigger orbit around them. This turns out to be the perfect laboratory for scientists to test just how far the equivalence principle goes.
By looking at PSR J0337+1715 for about six years, the paper’s authors can see whether or not that’s the case: If Einstein, and the strong equivalence principle, are right, then the inner pulsar-white dwarf pair should be stable, and the outer white dwarf’s gravity would affect them both the same. If Einstein’s wrong, then the scientists would see some kind of wobble as the neutron’s own gravity affects its orbit around the white dwarf.
Gravity Gains
Spoiler: Einstein won! He pretty much always wins.
The team saw exactly what they’d expect to see if the strong equivalence principle is right, no anomalies or weirdness, with a margin of error of only 30 meters, according to a university video explaining the findings.
This finding rules out several alternative theories, including some versions of string theory. It also confirms that our current understanding of gravity, the general theory of relativity, remains a reasonable way to understand the universe.
“Tests of this principle have a long heritage,” says Clifford M. Will in a Nature article accompanying the paper. “It is quite extraordinary that the responses of different materials to gravity should be so similar. In Einstein’s unique imagination, there was a reason: gravity is not a force that acts on all of these particles in some fantastically fine-tuned manner, but is simply an effect of space-time geometry. The constituents of matter follow universal paths in a space-time that is curved by massive bodies.”
Maybe one day we’ll have to discard Einstein’s theories for something better, but for now they’re still here to stay.
This article originally appeared on Discovermagazine.com.
Want to learn more about pulsars and other extreme objects in our universe? Check out our free downloadable eBook: Exotic objects: Black holes pulsars, and more.
