One planet is a massive, puffed-up oddity that could change ideas of how solar systems evolve. The other orbits a bright star and will allow astronomers to make detailed measurements of the atmospheres of these bizarre worlds.
One planet is located in the constellation Andromeda. Dubbed KELT-1b, it is so massive that it may better be described as a “failed star” rather than a planet. A superhot, superdense ball of metallic hydrogen, KELT-1b is located so close to its star that it whips through an entire “yearly” orbit in a little over a day — all the while being blasted by 6,000 times the radiation Earth receives from the Sun. What’s more, the planet appears to have been jostled in the past by a previously unknown distant binary companion star that is orbiting the KELT-1 solar system. In short, the planet “resets the bar for weird,” said Scott Gaudi from the Ohio State University in Columbus.
The other planet, KELT-2Ab, is located in the constellation Auriga and is typical of many previously discovered extrasolar planets in that it resembles Jupiter. But its parent star is bright — so bright that astronomers believe that they will be able to directly observe KELT-2Ab’s atmosphere by studying the starlight that shines through it and the infrared heat that radiates from it, using telescopes located not only in space, but also on the ground. “Normally, we would need a space telescope to do all that, but in this case, the host star is so bright that we can make many of these measurements from the ground,” said Thomas Beatty, also of Ohio State.
Astronomers at Ohio State and Vanderbilt University in Tennessee jointly operate KELT North and its twin, KELT South, in order to fill a large gap in the available technologies for finding extrasolar planets. Other telescopes were designed to look at faint stars in tiny sections of the sky, and at high resolution, Beatty explained. The KELTs, in contrast, look at millions of bright stars at once, over broad sections of sky, and at low resolution. “Our stars are so bright, these more powerful telescopes can’t even look at them,” Beatty said.
The KELT team scans those bright stars and watches to see if the starlight dims just a little — an indication that a planet has crossed in front of the star. The technique is called the “transit method” and takes advantage of situations such as the recent transit of Venus across the face of the Sun. It’s a low-cost means of planet-hunting, using mostly off-the-shelf technology. A traditional astronomical telescope costs millions of dollars to build, the hardware for a KELT runs less than $75,000.
“Exoplanets like KELT-1b and KELT-2Ab that pass directly in front of very bright stars are extremely important, but extremely rare, because there just aren’t that many very bright stars in the sky,” said Keivan Stassun of Vanderbilt University. “The KELT-North and KELT-South partnership gives us the advantage of hunting for these rare gems from both hemispheres, doubling the hunting grounds.” KELT North covers the northern sky, while KELT South, located near Cape Town, South Africa, covers the southern sky. Both newly discovered planets were found using KELT North.
The more typical of the two planets, KELT-2Ab, is 30 percent larger than Jupiter with 50 percent more mass. It resides in a binary system called HD 42176, with one star that is slightly bigger than our Sun and another star that is slightly smaller. KELT-2Ab orbits the bigger star, which is bright enough to be seen from Earth with binoculars. That’s why astronomers hope to be able to measure the starlight that passes through KELT-2Ab’s atmosphere when the star returns to KELT North’s field of view this November.
KELT-1b, in contrast, is one of the most bizarre transiting companions ever detected. It orbits a star not unlike our Sun, but the similarity to our solar system ends there. The planet is slightly larger than Jupiter, but contains 27 times the mass. Thus, it qualifies as a “failed star,” or brown dwarf. Although it is made primarily of hydrogen, it is so massive and compressed that its density matches that of the densest naturally occurring element on Earth — osmium, a shiny bluish metal found in platinum ore that is approximately twice as dense as lead.
Because it orbits its host star once every 30 hours, a solar “year” on KELT-1b passes in a little more than one Earth day. And because it orbits so closely, it is blasted with 6,000 times the amount of stellar radiation than we are exposed to on Earth. Its surface temperature is likely above 4000° Fahrenheit (2200° Celsius).
By comparison, the planet Mercury orbits our Sun once every 88 days, and the hottest temperature on the surface reaches only 800° F (more than 425° C).
Likely in response to the intense radiation, KELT-1b has inflated to a larger size than astronomers would normally predict. “This is the first definitively inflated brown dwarf found, and exactly how this happened is a complete mystery that should keep theorists busy for a while,” Gaudi said.
KELT-1b is a strange world, indeed. If you could stand on the surface, the “sun” would take up one quarter of the sky overhead. Fewer than 1 percent of the extrasolar planets ever discovered have been both extremely massive and extremely close to their host stars.
“This is a great system for studying orbital dynamics,” said Robert Siverd from Vanderbilt. “It has the strongest tides of any brown dwarf system found so far.”
KELT-1b and its star are locked in a cosmic dance that resembles that of Earth and the Moon, with a notable exception. The Moon is tidally locked to Earth — that’s why we always see the same face of the Moon — but Earth is not tidally locked to the Moon.
KELT-1b exerts so much gravitational force on its star that the star’s rotation rate actually matches the planet’s orbit — the two are tidally locked in each other’s gaze, for now. In a few billion years, KELT-1b’s star will expand and swallow the planet whole.
Gaudi said that astronomers are beginning to suspect that something unusual happens during the evolution of such solar systems that drives massive planets into these kinds of close encounters. The presence of a stellar sibling orbiting both of the newly discovered solar systems may be a “smoking gun” clue that past interactions between the planets, and these distant siblings is an important part of that process.
“We think they are born at much larger, colder distances,” he said, “and then like retirees moving to Florida, they move to warmer climes as they get older.”
