First gamma-ray clock found
Astronomers discover a gamma-ray signal from binary system LS5039.Provided by the Particle Physics and Astronomy Research Council, United Kingdom
By | Published: November 27, 2006 | Last updated on May 18, 2023
Gamma-ray Burst
Astronomers think gamma-ray bursts may be linked to black holes but aren’t sure of the exact circumstances of their creation. One idea is that gamma-ray bursts are produced after a massive star explodes and leaves a black hole in its place. Another idea is that they’re produced when two neutron stars collide to form a black hole. The appearance of a gamma-ray burst is unpredictable, but one appears about once per day.
ESA / ECF
November 27, 2006
Astronomers using the H.E.S.S. telescopes have discovered the first ever modulated signal from space in Very High Energy Gamma Rays — the most energetic such signal ever observed. Regular signals from space have been known since the 1960s, when the first radio pulsar (nicknamed Little Green Men-1 for its regular nature) was discovered. This is the first time a signal has been seen at such high energies — 100,000 times higher than previously known — and is reported November 24th in the journal Astronomy and Astrophysics.
The signal comes from a system called LS 5039 which was discovered by the H.E.S.S. team in 2005. LS5039 is a binary system formed of a massive blue star (20 times the mass of the Sun) and an unknown object, possibly a black hole. The two objects orbit each other at very short distance, varying between only 1/5 and 2/5 of the separation of the Earth from the Sun, with one orbit completed every four days.
“The way in which the gamma ray signal varies makes LS5039 a unique laboratory for studying particle acceleration near compact objects such as black holes,” explained Dr Paula Chadwick from the University of Durham, a British team member of H.E.S.S.
Different mechanisms can affect the gamma-ray signal that reaches Earth and by seeing how the signal varies, astronomers can learn a great deal about binary systems such as LS 5039 and also the effects that take place near black holes.
As it dives towards the blue-giant star, the compact companion is exposed to the strong stellar ‘wind’ and the intense light radiated by the star, allowing on the one hand particles to be accelerated to high energies, but at the same time making it increasingly difficult for gamma rays produced by these particles to escape, depending on the orientation of the system with respect to us. The interplay of these two effects is at the root of the complex modulation pattern.
The gamma-ray signal is strongest when the compact object (thought to be a black hole) is in front of the star as seen from Earth and weakest when it is behind the star. The gamma rays are thought to be produced as particles which are accelerated in the star’s atmosphere (the stellar wind) interact with the compact object. The compact object acts as a probe of the star’s environment, showing how the magnetic field varies depending on distance from the star by mirroring those changes in the gamma ray signal.
In addition, a geometrical effect adds a further modulation to the flux of gamma-rays observed from the Earth. We know since Einstein derived his famous equation (E=mc2) that matter and energy are equivalent, and that pairs of particles and antiparticles can mutually annihilate to give light. Symmetrically, when very energetic gamma rays meet the light from a massive star, they can be converted into matter (an electron-positron pair in this case). So, the light from the star resembles, for gamma rays, a fog which masks the source of the gamma rays when the compact object is behind the star, partially eclipsing the source.
“The periodic absorption of gamma-rays is a nice illustration of the production of matter-antimatter pairs by light, though it also obscures the view to the particle accelerator in this system,” said Guillaume Dubus, Astrophysical Laboratory of the Grenoble Observatory, LAOG.
