Herschel finds hot gas on the menu for Milky Way’s black hole
The space observatory has made detailed observations of hot molecular gas that may be orbiting or falling toward the supermassive black hole lurking at the center of our galaxy.
By | Published: May 7, 2013 | Last updated on May 18, 2023
Galactic center
The galactic center hosts a supermassive black hole in the region known as Sagittarius A*, or Sgr A*, with a mass of about 4 million times that of our Sun. A dense torus of molecular gas and dust surrounds the galactic center and occupies the innermost 15 light-years of our galaxy. Enshrouded within the disk is a central cavity, with a radius of a few light-years, filled with warm dust and lower density gas. Part of this gas is being heated by the strong ultraviolet radiation from massive stars that closely orbit the central black hole. Heating also likely results from strong shocks, generated as gas orbits around or flows towards Sgr A*, in collisions between gas clouds or in material flowing at high velocity from stars and protostars. // ESA–C. Carreau
The European Space Agency’s (ESA) Herschel Space Observatory has made detailed observations of surprisingly hot molecular gas that may be orbiting or falling toward the supermassive black hole lurking at the center of our Milky Way Galaxy.
Our local black hole is located in a region known as Sagittarius A* — Sgr A* — after a nearby radio source. It has a mass about 4 million times that of our Sun and lies around 26,000 light-years away from the solar system.
Even at that distance, it is a few hundred times closer to us than any other galaxy with an active black hole at its center, making it the ideal natural laboratory to study the environment around these enigmatic objects.
Vast amounts of dust lie in the plane of the Milky Way between here and its center, obscuring our view at visible wavelengths. But at far-infrared wavelengths, it is possible to peer through the dust, affording Herschel’s scientists the chance to study the turbulent innermost region of our galaxy in great detail.
Herschel has detected a great variety of simple molecules at the Milky Way’s heart, including carbon monoxide, water vapor, and hydrogen cyanide. By analyzing the signature from these molecules, astronomers have been able to probe some of the fundamental properties of the interstellar gas surrounding the black hole.
“Herschel has resolved the far-infrared emission within just 1 light-year of the black hole, making it possible for the first time at these wavelengths to separate emission due to the central cavity from that of the surrounding dense molecular disk,” said Javier Goicoechea of the Astrobiology Center in Spain.
The biggest surprise was how hot the molecular gas in the innermost central region of the galaxy gets. At least some of it is around 1800° Fahrenheit (1000° Celsius), much hotter than typical interstellar clouds, which are usually only a few tens of degrees above the –460°F (–273°C) of absolute zero.
While some of the heating is due to the fierce ultraviolet radiation pouring from a cluster of massive stars that live very close to the galactic center, they are not enough to explain the high temperatures alone.
In addition to the stellar radiation, Goicoechea’s team hypothesize that emission from strong shocks in highly magnetized gas in the region may be a significant contributor to the high temperatures. Such shocks can be generated in collisions between gas clouds or in material flowing at high speed from stars and protostars.
“The observations are also consistent with streamers of hot gas speeding towards Sgr A*, falling towards the very center of the galaxy,” said Goicoechea. “Our galaxy’s black hole may be cooking its dinner right in front of Herschel’s eyes.”
Just before material falls into a black hole, it is heated up enormously and can cause high-energy X-ray and gamma-ray flares. While Sgr A* currently shows little sign of such activity, this could change soon.
Using near-infrared observations, other astronomers have spotted a separate, compact cloud of gas amounting to just a few Earth masses spiraling toward the black hole. Located much closer to the black hole than the reservoir of material studied by Herschel in this work, it may finally be gobbled up later this year.
Spacecraft including ESA’s XMM-Newton and Integral will be waiting to spot any high-energy burps as the black hole enjoys its feast.
“The center of the Milky Way is a complex region, but with these Herschel observations, we have taken an important step forward in our understanding of the vicinity of a supermassive black hole, which will ultimately help improve our picture of galaxy evolution,” said Göran Pilbratt from ESA.
