Hubble uncovers surprising evidence for an extrasolar planet under construction
The suspected protoplanet is orbiting the diminutive red dwarf TW Hydrae at a distance that challenges current planet-formation theories.
By and | Published: June 14, 2013 | Last updated on May 18, 2023
TW Hydrae protoplanetary disk
This graphic shows a gap in a protoplanetary disk of dust and gas whirling around the nearby red dwarf star TW Hydrae. The gap’s presence is best explained as due to the effects of a growing, unseen planet that is gravitationally sweeping up material and carving out a lane in the disk, like a snow plow. In the NASA Hubble Space Telescope image at left, a gap can be seen about 7.5 billion miles (12.1 billion km) away from the star in the center of the disk. If the putative planet orbited in our solar system, it would be roughly twice Pluto’s distance from our Sun. The image was taken in near-infrared light by the Near Infrared Camera and Multi-Object Spectrometer (NICMOS). // NASA/ESA/J. Debes (STScI)/H. Jang-Condell (Univ. of Wyoming)/A. Weinberger (CIW)/A. Roberge (GSFC)/G. Schneider (Univ. of Arizona/Steward Observatory)/A. Feild (STScI/AURA)
Astronomers using NASA’s Hubble Space Telescope have found compelling evidence of a planet forming 7.5 billion miles (12.1 billion km) away from its star, a finding that may challenge current theories about planet formation.
Of the almost 900 planets outside our solar system that have been confirmed to date, this is the first to be found at such a great distance from its star. The suspected planet is orbiting the diminutive red dwarf TW Hydrae, a popular astronomy target located 176 light-years away from Earth in the constellation Hydra the Sea Serpent.
Hubble’s keen vision detected a mysterious gap in a vast protoplanetary disk of gas and dust swirling around TW Hydrae. The gap is 1.9 billion miles (3.1 billion kilometers) wide, and the disk is 41 billion miles (66 billion km) wide. The gap’s presence likely was caused by a growing, unseen planet that is gravitationally sweeping up material and carving out a lane in the disk, like a snow plow.
The planet is estimated to be relatively small, at six to 28 times more massive than Earth. Its wide orbit means it is moving slowly around its host star. If the suspected planet were orbiting in our solar system, it would be roughly twice Pluto’s distance from the Sun.
Planets are thought to form over tens of millions of years. The buildup is slow, but persistent as a budding planet picks up dust, rocks, and gas from the protoplanetary disk. A planet 7.5 billion miles from its star should take more than 200 times longer to form than Jupiter did at its distance from the Sun because of its much slower orbital speed and the deficiency of material in the disk. Jupiter is 500 million miles (800 million km) from the Sun and it formed in about 10 million years.
TW Hydrae is only 8 million years old, making it an unlikely star to host a planet, according to this theory. There has not been enough time for a planet to grow through the slow accumulation of smaller debris. Complicating the story further is that TW Hydrae is only 55 percent as massive as our Sun.
“It’s so intriguing to see a system like this,” said John Debes of the Space Telescope Science Institute in Baltimore, Maryland, and leader of the research team that identified the gap. “This is the lowest-mass star for which we’ve observed a gap so far out.”
An alternative planet-formation theory suggests that a piece of the disk becomes gravitationally unstable and collapses on itself. In this scenario, a planet could form more quickly, in just a few thousand years.
“If we can actually confirm that there’s a planet there, we can connect its characteristics to measurements of the gap properties,” Debes said. “That might add to planet-formation theories as to how you can actually form a planet very far out.”
The TW Hydrae disk also lacks large dust grains in its outer regions. Observations from the Atacama Large Millimeter/submillimeter Array in Chile show dust grains roughly the size of a grain of sand are not present beyond about 5.5 billion miles (8.9 billion km) from the star, just short of the gap.
“Typically, you need pebbles before you can have a planet. So, if there is a planet and there is no dust larger than a grain of sand farther out, that would be a huge challenge to traditional planet formation models,” Debes said.
The team used Hubble’s Near Infrared Camera and Multi-Object Spectrometer (NICMOS) to observe the star in near-infrared light. The researchers then compared the NICMOS images with archival Hubble data and optical and spectroscopic observations from Hubble’s Space Telescope Imaging Spectrograph (STIS). Debes said researchers see the gap at all wavelengths, which indicates it is a structural feature and not an illusion caused by the instruments or scattered light.
