NASA spacecraft ready to explore outer solar system
The new spacecraft will allow scientists to understand the global reaction between our Sun and the galaxy.Provided by NASA Headquarters, Washington, D.C.
By | Published: October 6, 2008 | Last updated on May 18, 2023
Voyager 1
Voyager 1 has traveled toward the boundary between our solar system and interstellar space.
JPL/NASA
October 6, 2008
The first NASA spacecraft to image and map the dynamic interactions taking place where the hot solar wind slams into the cold expanse of space is ready for launch October 19. The 2-year mission will begin from the Kwajalein Atoll, a part of the Marshall Islands in the Pacific Ocean.
The Interstellar Boundary Explorer (IBEX) will conduct extremely high-altitude orbits of Earth to investigate and capture images of processes taking place at the farthest reaches of the solar system. Known as the interstellar boundary, this region marks where the solar system meets interstellar space.
“The interstellar boundary regions are critical because they shield us from the vast majority of dangerous galactic cosmic rays, which otherwise would penetrate into Earth’s orbit and make human spaceflight much more dangerous,” says David J. McComas, IBEX principal investigator and senior executive director of the Space Science and Engineering Division at the Southwest Research Institute in San Antonio.
The story of the outer solar system began to unfold when the Voyager 1 and Voyager 2 spacecrafts left the inner solar system and headed out toward the boundary between our solar system and interstellar space.
“The Voyager spacecraft are making fascinating observations of the local conditions at two points beyond the termination shock that show totally unexpected results and challenge many of our notions about this important region,” says McComas.
Other spacecraft have continued the exploration of the interstellar boundary region. Recently, a pair of NASA Sun-focused satellites, the Solar Terrestrial Relations Observatory mission, detected a higher-energy version of the particles IBEX will observe in the heliosphere, an area that contains the solar wind. It stretches from the Sun to a distance several times the orbit of Pluto.
IBEX is poised to thoroughly map this interstellar boundary region of the solar system. The images will allow scientists to understand the global interaction between our Sun and the galaxy for the very first time.
IBEX will be launched aboard a Pegasus rocket dropped from under the wing of an L-1011 aircraft flying over the Pacific Ocean. The Pegasus will carry the spacecraft approximately 130 miles (209 kilometers) above Earth and place it in orbit.
“What makes the IBEX mission unique is that it has an extra kick during launch,” says Willis Jenkins, IBEX program executive at NASA Headquarters in Washington. “An extra solid-state motor pushes the spacecraft further out of low-Earth orbit where the Pegasus launch vehicle leaves it.”
