‘Stellar cannibalism’ is key to formation of overweight stars
Researchers discovered a connection between the total mass contained in the core of a globular cluster and the number of blue stragglers observed within it.Provided by the Science and Technology Facilities Council, United Kingdom
By | Published: January 14, 2009 | Last updated on May 18, 2023
Blue stragglers in globular cluster 47 Tucanae
The core of globular cluster 47 Tucanae is home to many blue stragglers, rejuvenated stars that glow with the blue light of young stars. A ground-based telescope image (on the left) shows the entire crowded core of 47 Tucanae, located 15,000 light-years away in the constellation Tucana. Peering into the heart of the globular cluster’s bright core, the Hubble Space Telescope’s Wide Field and Planetary Camera 2 separated the dense clump of stars into many individual stars (image on right). Some of these stars shine with the light of old stars; others with the blue light of blue stragglers. The yellow circles in the Hubble telescope image highlight several of the cluster’s blue stragglers.
NASA-Goddard Space Flight Center
January 14, 2009
Researchers have discovered that the mysterious overweight stars known as blue stragglers are the result of ‘stellar cannibalism’ where plasma is gradually pulled from one star to another to form a massive, unusually hot star that appears younger than it is. The process takes place in binary stars – star systems consisting of two stars orbiting around their common center of mass. This helps to resolve a long-standing mystery in stellar evolution.
Blue stragglers are found throughout the universe in globular clusters of about 100,000 stars, tightly bound by gravity. According to conventional theories, the massive blue stragglers found in these clusters should have died long ago, because all stars in a cluster are born at the same time and should therefore be at a similar phase. These massive rogue stars, however, appear to be much younger than the other stars and are found in virtually every observed cluster.
Dr. Christian Knigge from Southampton University in United Kingdom, who led the study, said, “The origin of blue stragglers has been a long-standing mystery. The only thing that was clear is that at least two stars must be involved in the creation of every single blue straggler, because isolated stars this massive simply should not exist in these clusters.”
Professor Alison Sills from the McMaster University in Hamilton, Ontario, Canada, said, “We’ve known of these stellar anomalies for 55 years. Over time, two main theories have emerged: that blue stragglers were created through collisions with other stars; or that one star in a binary system was ‘reborn’ by pulling matter off its companion.”
The researchers looked at blue stragglers in 56 globular clusters. They found that the total number of blue stragglers in a given cluster did not correlate with the predicted collision rate – dispelling the theory that blue stragglers are created through collisions with other stars.
They did, however, discover a connection between the total mass contained in the core of the globular cluster and the number of blue stragglers observed within it. Since more massive cores also contain more binary stars, they were able to infer a relationship between blue stragglers and binaries in globular clusters. They also showed that this conclusion is supported by preliminary observations that directly measured the abundance of binary stars in cluster cores. All of this points to ‘stellar cannibalism’ as the primary mechanism for blue straggler formation.
Knigge said, “This is the strongest and most direct evidence to date that most blue stragglers, even those found in the cluster cores, are the offspring of two binary stars. In our future work, we will want to determine whether the binary parents of blue stragglers evolve mostly in isolation, or whether dynamical encounters with other stars in the clusters are required somewhere along the line in order to explain our results.”
