Strange ring circles dead star
Object probably formed from supernova explosion.Provided by the Jet Propulsion Laboratory, Pasadena, California
By | Published: May 29, 2008 | Last updated on May 18, 2023
Magnetar
Magnetars are neutron stars with extremely powerful magnetic fields.
NASA/Swift/Sonoma State University/A. Simonnet
May 29, 2008
NASA’s Spitzer Space Telescope has found a bizarre ring of material around the magnetic remains of a star that blasted to smithereens.
The stellar corpse, SGR 1900+14, belongs to a class of objects known as magnetars. These are the cores of massive stars that blew up in supernova explosions, but unlike other dead stars, they slowly pulsate with X-rays and have tremendously strong magnetic fields.
“The universe is a big place and weird things can happen,” said Stefanie Wachter of NASA’s Spitzer Science Center at the California Institute of Technology, Pasadena, who found the ring serendipitously. “I was flipping through archived Spitzer data of the object, and that’s when I noticed it was surrounded by a ring we’d never seen before.” Wachter is lead author of a paper about the findings in this week’s Nature.
Wachter and her colleagues think that the ring, which is unlike anything ever seen before, formed in 1998 when the magnetar erupted in a giant flare. They believe the crusty surface cracked, sending out a flare, or blast of energy, that excavated a nearby cloud of dust, leaving an outer, dusty ring. This ring is oblong, with dimensions of about 7 by 3 light-years. It appears to be flat, or two-dimensional, but the scientists can’t rule out the possibility of a three-dimensional shell.
“It’s as if the magnetar became a huge, flaming torch and obliterated the dust around it, creating a massive cavity,” said Chryssa Kouveliotou, senior astrophysicist at NASA’s Marshall Space Flight Center in Huntsville, Alabama, and a co-author of the paper. “Then, the stars nearby lit up a ring of fire around the dead star, marking it for eternity.”
The discovery could help scientists figure out if a star’s mass influences whether it becomes a magnetar when it dies. Though scientists know that stars above a certain mass will “go supernova,” they do not know if mass plays a role in determining whether the star becomes a magnetar or a run-of-the-mill dead star. The ring shows that SGR 1900+14 belongs to a nearby cluster of young, massive stars. By studying the masses of these nearby stars, the scientists might learn the approximate mass of the original star that exploded and became SGR 1900+14.
“The ring has to be lit up by something, otherwise Spitzer wouldn’t have seen it,” said Enrico Ramirez-Ruiz of the University of California, Santa Cruz. “The nearby massive stars are most likely what’s heating the dust and lighting it up, and this means that the magnetar is associated with the massive star-forming region.”
Rings and spheres are common in the universe. Young, hot stars blow bubbles in space, carving out dust into spherical shapes. When stars die in supernova explosions, their remains are blasted into space,
forming short-lived orbs called supernova remnants. Rings can also form around exploded stars whose expanding shells of debris ram into pre-existing dust rings, causing the dust to glow.
But the ring around SGR 1900+14 fits into none of these categories. Supernova remnants and the ring around 1987A cry out with X-rays and radio waves. The ring around SGR 1900+14 only glows at specific infrared wavelengths.
At first, the astronomers thought the ring must be an infrared echo. These occur when an object sends out a blast wave that travels outward, heating dust and causing it to glow with infrared light. But when they went back to observe SGR 1900+14, the ring didn’t move outward as it should have.
Closer analysis of the pictures later revealed that the ring is most likely a carved-out cavity in a dust cloud — a phenomenon that must be somewhat rare in the universe since it had not been seen before. The scientists plan to look for more of these rings.
