“We have looked at this region at the center of the Milky Way many times before in the infrared,” said Alberto Noriega-Crespo from the California Institute of Technology in Pasadena. “But when we looked at the high-resolution images using Herschel’s submillimeter wavelengths, the presence of a ring is quite clear.”
The Herschel Space Observatory is a European Space Agency-led mission with important NASA contributions. It sees infrared and submillimeter light, which can readily penetrate through the dust, hovering between the bustling center of our galaxy and us. Herschel’s detectors are also suited to see the coldest stuff in our galaxy.
When astronomers turned the giant telescope to look at the center of our galaxy, it captured unprecedented views of its inner ring — a dense tube of cold gas mixed with dust where new stars are forming.
Astronomers were shocked by what they saw — the ring, which is in the plane of our galaxy, looked more like an infinity symbol with two lobes pointing to the side. In fact, they later determined the ring was torqued in the middle, so it only appears to have two lobes. To picture the structure, imagine holding a stiff, elliptical band and twisting the ends in opposite directions so that one side comes up a bit.
“This is what is so exciting about launching a new space telescope like Herschel,” said Sergio Molinari from the Institute of Space Physics in Rome, Italy. “We have a new and exciting mystery on our hands, right at the center of our own galaxy.”
Observations with the ground-based Nobeyama Radio Observatory in Japan complemented the Herschel results by determining the velocity of the denser gas in the ring. The radio results demonstrate that the ring is moving together as a unit, at the same speed relative to the rest of the galaxy.
The ring lies at the center of our Milky Way’s bar — a bar-shaped region of stars at the center of its spidery spiral arms. This bar is actually inside an even larger ring. Other galaxies have similar bars and rings. A classic example of a ring inside a bar is in the galaxy NGC 1097. The ring glows brightly in the center of the galaxy’s large bar structure. It is not known if that ring has a kink or not.
The details of how bars and rings form in spiral galaxies are not well understood, but computer simulations demonstrate how gravitational interactions can produce the structures. Some theories hold that bars arise out of gravitational interactions between galaxies. For example, Andromeda, our largest neighbor galaxy, might have influenced the bar at the center of the Milky Way.
The twist in the ring is not the only mystery to come out of the new Herschel observations. Astronomers say that the center of the torqued portion of the ring is not where the center of the galaxy is thought to be, but slightly offset. The center of our galaxy is considered to be around Sagittarius A* where a massive black hole lies. According to Noriega-Crespo, it’s not clear why the center of the ring doesn’t match up with the assumed center of our galaxy. “There’s still so much about our galaxy to discover,” he said.
