Astroimager James R. Foster resides in downtown Los Angeles. Light pollution there relegates most celestial objects dimmer than magnitude 3 — easily seen under a dark sky — to the “challenge-to-image” category. Foster uses a variety of astroimaging techniques to overcome urban light pollution and capture stunning images of some of the sky’s best sights. Here are a few of the images he’s shot from his home using a 13-inch Cassegrain f/7.5 telescope and an SBIG ST-7E CCD camera.
IC 1470
IC 1470 is a comet-shape emission nebula in Cepheus that spans about 15′. A 12th-magnitude star lies near its center. Rudolph Spitaler discovered the nebula, also known as Sh 2-156, in 1892. Foster combined two lumenence (L) frames of 60 and 30 minutes, respectively — one from Los Angeles and one from Mt. Pinos, California — with RGB frames of 30, 60, and 60 minutes, respectively, to compose this image.
IC 1470
NGC 246 is a planetary nebula some 1,600 light-years distant in Cetus. Also called the Skull Nebula, it spans 4′ and has an apparent magnitude of about 8. NGC 246’s 12th-magnitude central star HIP 3678 is actually two stars. This composite image combines LRGB frames.
NGC 925
Face-on spiral galaxy NGC 925 in Triangulum appears some 9.8″ in diameter and has an apparent magnitude of about 10.5. Foster shot L and R frames from Los Angeles and combined them with RGB frames taken at Mt. Pinos to create this composite image.
The Fireworks Galaxy (NGC 6946) is a 9.6-magnitude, 12′-wide, face-on spiral that lies 10–20 million light-years away on the border between Cepheus and Cygnus. SN 2004et, a young type II supernova, had a magnitude of 12.8 when Stefano Moretti discovered it September 27, 2004, with a 16-inch (0.4 meter) telescope. Foster combined LRGB frames to compose this image.
James R. Foster
NGC 6946 and SN 2004et
The Fireworks Galaxy (NGC 6946) is a 9.6-magnitude, 12′-wide, face-on spiral that lies 10-20 million light-years away on the border between Cepheus and Cygnus. SN 2004et, a young type II supernova, had a magnitude of 12.8 when Stefano Moretti discovered it September 27, 2004, with a 16-inch (0.4 meter) telescope. Foster combined LRGB frames to compose this image.
NGC 7380
Magnitude 7.2 open star cluster NGC 7380 is some 7,000 light-years distant in Cepheus. Caroline Herschel discovered it in 1787. Emission nebula Sh 2-142 surrounds the cluster. Foster shot LRGB frames of 100, 60, 60, and 60 minutes, respectively, to create this image.
NGC 7640
NGC 7640 is a magnitude 10.9 barred spiral galaxy in Andromeda. Seen edge-on and spanning about 10.7′, NGC 7640 is 19 million light-years away. Foster shot individual LRGB frames and combined them into this composite image.
PK 85+4.1
Planetary nebula PK 85+4.1 in Cygnus is also known as Abell 71. An OIII filter helps locate this faint, magnitude 15.2 nebula, which appears as a 2.8′ by 2.5′ roundish haze. Foster imaged PK 85+4.1 in LRGB frames of 90, 60, 60, and 60 minutes, respectively.
PK 102-2.1
PK 102-2.1 is a faint, 15th-magnitude planetary nebula found in the constellation Lacerta. The nebula is also known as Abell 79. An OIII filter will help locate this challenging planetary. Foster imaged PK 102-2.5 in LRGB. The L component of this image comprises 72 minutes.
IC 1470
NGC 925
James R. Foster
NGC 7380
NGC 7640
PK 85+4.1
PK 102-2.1
