What is dead may never die
Astronomers discovered a bizarre "zombie" star that went supernova not just once, but twice.
By | Published: November 8, 2017 | Last updated on May 18, 2023
SNconcept
In this artist’s concept of a supernova, an expanding shell of dust and gas is blown outward, away from the star’s dense, white-dwarf core. Most supernovae explode just once, which ends their lives for good. However, iPTF14hls appears to have gone supernova twice in just 60 years.
NASA/ESA/STSCI/G. Bacon
To quote the first line of a letter published today in the journal Nature, “Every supernova so far observed has been considered to be the terminal explosion of a star.” In other words, when a massive star blows itself up, it should remain dead. This is something astronomers have witnessed thousands of times before with absolutely no exceptions.
That is, until now.
For the first time, astronomers have discovered a star that has gone supernova more than once. This so-called “zombie star” — which exploded at least twice in the last 60 years alone — has baffled scientists by challenging many of the existing theories about how massive stars end their lives.
“This supernova breaks everything we thought we knew about how they work,” said the study’s lead author Iair Arcavi, a NASA Einstein Postdoctoral Fellow at the University of California-Santa Barbara and Las Cumbres Observatory, in a press release. “It’s the biggest puzzle I’ve encountered in almost a decade of studying stellar explosions.”
The undying star, named iPTF14hls, was first discovered in September 2014 by the Palomar Transient Factory (PTF), a fully automated, wide-field survey designed to spot cosmic objects that vary in brightness over time — such as variable stars, transient objects, and, of course, supernovae.
SNbrightness
Over the course of two years, iPTF14hls grew and dropped in brightness at least five times. Most supernovae remain bright for around 100 days before fading for good.
LCO/S. Wilkinson
When the international team of astronomers first spotted the explosion, a spectral analysis indicated it was just a run-of-the-mill, Type II-P supernova whose brightness would likely fade after about 100 days. Supernova iPTF14hls, on the other hand, had a different plan.
Although Supernova iPTF14hls initially faded after its 2014 explosion, within a few months it began to mysteriously grow brighter again. Over the course of three years, iPTF14hls fluctuated between bright and dim at least five separate times.
“This [was] one of those head-scratcher type of events,” said co-author Peter Nugent, a senior scientist at Lawrence Berkeley National Laboratory. “At first we thought it was completely normal and boring. Then it just kept staying bright, and not changing, for month after month.”
When the astronomers realized iPTF14hls was not an average supernova, they decided to go back and search through archival data. The researchers were flabbergasted when they found that in 1954, another explosion was recorded in the exact same location as iPTF14hls. Somehow, the star survived its first explosion, waited 60 years, and then exploded again.
SNcomparison
An image taken by the Palomar Observatory Sky Survey reveals a possible explosion in 1954 at the exact location of iPTF14hls (left). It is not seen in the later image taken in 1993 (right).
POSS/DSS/LCO/S. Wilkinson
Although researchers are still uncertain what caused iPTF14hls to go supernova twice, one theory is that the “zombie star” is actually a “pulsation pair instability supernova.”
“According to this theory, it is possible that this was the result of a star so massive and hot that it generated antimatter in its core,” said co-author Daniel Kasen, a professor of physics and astronomy at the University of California-Berkeley. “That would cause the star to go violently unstable, and undergo repeated bright eruptions over periods of years.” The authors of the study calculated that before the first explosion, the star was at least 50 times as massive as the Sun (and likely larger).
“These explosions were only expected to be seen in the early universe and should be extinct today,” said co-author Andy Howell, leader of the LCO supernova group. “This is like finding a dinosaur still alive today. If you found one, you would question whether it truly was a dinosaur.”
Using LCO’s global telescope network, which is specifically designed for sustained observations, astronomers will continue to monitor iPTF14hls for changes in brightness over time.
“We could not have kept tabs on iPTF14hls for this long and collected data that challenges all existing supernova theories if it weren’t for the global telescope network,” said Arcavi. “I can’t wait to see what we’ll find by continuing to look at the sky in the new ways that such a setup allows.”
