WISE finds few brown dwarfs close to home
Previous estimates had predicted as many of these “failed” suns as typical stars, but the new initial tally from WISE shows just one brown dwarf for every six stars.
By | Published: June 11, 2012 | Last updated on May 18, 2023
Brown-dwarfs-nearby
This image shows our own backyard, astronomically speaking, from a vantage point about 30 light-years away from the Sun. It highlights the population of tiny brown dwarfs recently discovered by NASA’s Wide-field Infrared Survey Explorer, or WISE (red circles). The image simulates actual positions of stars.
NASA/JPL-Caltech
Astronomers are getting to know the neighbors better. Our Sun resides within a spiral arm of the Milky Way Galaxy about two-thirds of the way out from the center. It lives in a fairly calm, suburb-like area with an average number of stellar residents. Recently, NASA’s Wide-field Infrared Survey Explorer (WISE) has been turning up a new crowd of stars close to home: the coldest of the brown dwarf family of “failed” stars.
Now, just as scientists are “meeting and greeting” the new neighbors, WISE has a surprise in store: There are far fewer brown dwarfs around us than predicted.
“This is a really illuminating result,” said Davy Kirkpatrick of the WISE science team at NASA’s Infrared Processing and Analysis Center at the California Institute of Technology in Pasadena. “Now that we’re finally seeing the solar neighborhood with keener, infrared vision, the little guys aren’t as prevalent as we once thought.”
Previous estimates had predicted as many brown dwarfs as typical stars, but the new initial tally from WISE shows just one brown dwarf for every six stars. It’s the cosmic equivalent to finally being able to see down a mysterious gated block and finding only a few homes.
Nonetheless, the observations provide crucial information about how these exotic worlds form and hint at what their population densities might be like in our galaxy and beyond.
“WISE is finding new cold worlds that are ripe for exploration in their own right,” said Kirkpatrick. “We think they can form by several different mechanisms, including having their growth stunted by a variety of factors that prevent them from becoming full-blown stars. Still, we don’t know exactly how this process works.”
WISE was launched in 2009 and surveyed the entire sky in infrared light in 2010. One of the mission’s main science goals was to survey the sky for these elusive brown dwarfs. These small bodies start their lives like stars, but lack the bulk required to burn nuclear fuel. With time, they cool and fade, making them difficult to find.
Improvements in WISE’s infrared vision over past missions have allowed it to pick up the faint glow of many of these hidden objects. In August 2011, the mission announced the discovery of the coolest brown dwarfs spotted yet, a new class of stars called Y dwarfs. One of the Y dwarfs is less than 80° Fahrenheit (25° Celsius), or about room temperature, making it the coldest star-like body known. Since then, the WISE science team has surveyed the entire landscape around our Sun and discovered 200 brown dwarfs, including 13 Y dwarfs.
Determining the distances to these objects is a key factor in knowing their population density in our solar neighborhood. After carefully measuring the distance to several of the coldest brown dwarfs via a method called parallax, scientists were able to estimate the distances to all of the newfound brown dwarfs. They concluded that about 33 brown dwarfs reside within 26 light-years of Sun. There are 211 stars within this same volume of space, so that means there are about six stars for every brown dwarf.
“Having fewer brown dwarfs than expected in our celestial backyard just means that each new one we discover plays a critical role in our overall understanding of these cold objects,” said Chris Gelino, a co-author of the new research who is also at the Infrared Processing and Analysis Center. “These brown dwarfs are fascinating objects that are bridging the gap between the coldest stars and Jupiter.”
Kirkpatrick emphasized that the results are still preliminary: It is highly likely that WISE will discover additional Y dwarfs, but not in vast numbers, and probably not closer than the closest known star, Proxima Centauri. Those discoveries could bring the ratio of brown dwarfs to stars up a bit, to about 1:5 or 1:4, but not to the 1:1 level previously anticipated.
“This is how science progresses as we obtain better and better data,” said Kirkpatrick. “With WISE, we were able to test our predictions and show they were wrong. We had made extrapolations based on discoveries from projects like the Two-Micron All-Sky Survey, but WISE is giving us our first look at the coldest brown dwarfs we’re only now able to detect.”
The new observations still allow the possibility of free-floating planets up to a few times the mass of Jupiter beyond a few light-years from the Sun, which other surveys have predicted might exist. Those bodies would be too faint for WISE to see in the processed data in hand.
