Holiday wishes from Hubble
Hubble has sent back an early Christmas card with this new NASA/ESA Hubble Space Telescope image of the nearby spiral galaxy Messier 74.Provided by Hubble ESA, Garching, Germany
By | Published: December 3, 2007 | Last updated on May 18, 2023
In the new Hubble image of the galaxy M74 we can also see a smattering of bright pink regions decorating the spiral arms.
NASA/ESA/The Hubble Heritage Team
December 3, 2007
The new Hubble image of Messier 74 is an enchanting reminder of the impending season. Resembling glittering baubles on a holiday wreath, bright knots of glowing gas light up the spiral arms; regions of new star birth shining in pink.
Messier 74, also called NGC 628, is a stunning example of a “grand-design” spiral galaxy that is viewed by Earth observers nearly face-on. Its perfectly symmetrical spiral arms emanate from the central nucleus and are dotted with clusters of young blue stars.
In the new Hubble image we can also see a smattering of bright pink regions decorating the spiral arms. These are huge, relatively short-lived, clouds of hydrogen gas which glow due to the strong radiation from hot, young stars embedded within them; glowing pink regions of ionized hydrogen (hydrogen that has lost its electrons). These regions of star formation show an excess of light at ultraviolet wavelengths and astronomers call them HII regions.
An image of the region of sky around M74, the “Phantom Galaxy”, from the Digitized Sky Survey 2. The field-of-view is approximately 2.8 x 2.8 degrees.
NASA/ESA/Digitized Sky Survey 2
Tracing along the spiral arms are winding dust lanes that begin very near the galaxy’s nucleus and follow along the length of the spiral arms. These spiral arms are not actually static “arms” like spokes on a wheel. They are in fact density waves and move around the galaxy’s disc compressing gas, just as sound waves compress the air on Earth, creating a new generation of young blue stars.
Messier 74 is located roughly 32 million light-years away in the direction of the constellation Pisces, the Fish. It is the dominant member of a small group of about half a dozen galaxies, the Messier 74 galaxy group. In its entirety, it’s estimated that Messier 74 is home to about 100 billion stars, making it slightly smaller than our Milky Way.
The spiral galaxy was first discovered by the French astronomer, Pierre Méchain, in 1780. Weeks later it was added to Charles Messier’s famous catalog of deep-sky objects. Of all the objects in Messier’s catalog, number 74 has the lowest surface brightness. It is so difficult for amateur astronomers to spot through a telescope that it has been given the nickname “The Phantom Galaxy.”
This Hubble image of Messier 74 is a composite of Advanced Camera for Surveys’ data taken in 2003 and 2005. The filters used to create the color image isolate light from blue, visible, and infrared portions of the spectrum, as well as emission from ionized hydrogen.
