Listen to Phoenix descend
What did it sound like when the lander headed toward the Red Planet's surface? Find out here.Provided by ESA, Noordwijk, Netherlands
By | Published: May 28, 2008 | Last updated on May 18, 2023
NASA’s Phoenix Mars Lander monitors the atmosphere overhead and reaches out to the soil below in this artist’s depiction of the spacecraft fully deployed on the surface of Mars. Phoenix will use a robotic arm to analyze scooped-up samples of soil and ice for factors that will help scientists evaluate whether the subsurface environment at the site ever was, or may still be, a favorable habitat for microbial life.
NASA/JPL/UA/Lockheed Martin
May 28, 2008
With data recorded on board Mars Express, you can hear Phoenix descend on to the surface of the Red Planet. After being processed by the Mars Express Flight Control Team, the sounds of Phoenix descending are audible, loud and clear.
The data from the Mars Express Lander Communication system (MELACOM) that tracked Phoenix was received on Earth soon after the Phoenix landing.
The spike in the animation, between frequencies of 7 and 8 kiloHertz, shows the transmission from Phoenix itself.
The lander can be seen in the animation starting from about 342 s after the start time and disappears at about 1085 s. This shows Mars Express picking up on the Phoenix signal and tracking it while closing in on the lander; the closest Mars Express got to Phoenix was 1550 km.
As Mars Express flew away, the lander deployed its parachute, separated from it and landed, the signal from the lander was cut off.
The shift of the spike seen in the animation, is due to the so-called Doppler effect, which is very similar to what we hear when listening to the whistle of a passing train.
The signal was tracked successfully, even during the expected transmission blackout window of the descent, until the lander was out of Mars Express’s view. The transmission blackout window is caused because of ionisation around the probe, which builds up as the lander descends through the atmosphere and only very weak signals come through.
The rest of the recording, the start and the end, contains background noise generated by Mars Express itself.
During the descent, all of the capabilities of Mars Express were focussed on tracking Phoenix with MELACOM. Unfortunately, the science observations carried out during the descent did not lead to the anticipated results.
Over the next few days, Mars Express will monitor Phoenix using MELACOM 15 more times; at least one of these will be used to demonstrate and confirm that the ESA spacecraft can be used as a data relay station for NASA, receiving data from the surface and transmitting test commands to the lander.
Detailed information about the descent and landing will be available once the data from all the fly-overs is processed and analysed over the next few weeks.
Downloadable File(s)
