Mars Odyssey to listen for Phoenix radio transmissions
NASA to check for unlikely winter survival of Mars lander.Provided by the Jet Propulsion Laboratory, Pasadena, California
By | Published: January 12, 2010 | Last updated on May 18, 2023
phoenix
This illustration shows NASA’s Phoenix Mars Lander on the Red Planet.
NASA/JPL-Calech/University of Arizona
January 12, 2010
Beginning January 18, NASA’s Mars Odyssey orbiter will listen for possible, though improbable, radio transmissions from the Phoenix Mars Lander, which completed five months of studying an arctic martian site November 2008.
The solar-powered lander operated two months longer than its three-month prime mission during summer on northern Mars before the seasonal ebb of sunshine ended its work. Since then, Phoenix’s landing site has gone through autumn, winter, and part of spring. The lander’s hardware was not designed to survive the temperature extremes and ice-coating load of an arctic martian winter.
In the extremely unlikely case that Phoenix survived the winter, it is expected to follow instructions programmed on its computer. If systems still operate, once its solar panels generate enough electricity to establish a positive energy balance, the lander would periodically try to communicate with any available Mars relay orbiters in an attempt to re-establish contact with Earth. During each communication attempt, the lander would alternately use each of its two radios and each of its two antennas.
Odyssey will pass over the Phoenix landing site approximately ten times each day during 3 consecutive days of listening this month and two longer listening campaigns in February and March.
“We do not expect Phoenix to have survived, and therefore do not expect to hear from it. However, if Phoenix is transmitting, Odyssey will hear it,” said Chad Edwards, chief telecommunications engineer for the Mars Exploration Program at NASA’s Jet Propulsion Laboratory, Pasadena, California. “We will perform a sufficient number of Odyssey contact attempts so that if we don’t detect a transmission from Phoenix, we can have a high degree of confidence that the lander is not active.”
The amount of sunshine at Phoenix’s site is currently about the same as when the lander last communicated November 2, 2008, with the Sun above the horizon about 17 hours each day. The listening attempts will continue until after the Sun is above the horizon for the full 24.7 hours of the martian day at the lander’s high-latitude site. During the later attempts in February or March, Odyssey will transmit radio signals that could potentially be heard by Phoenix, as well as passively listening.
If Odyssey does hear from Phoenix, the orbiter will attempt to lock onto the signal and gain information about the lander’s status. The initial task would be to determine what capabilities Phoenix retains, information that NASA would consider in decisions about any further steps.
